Hi,
Are there any blocks I can check too determine if a 2004 A3 2.0 TDI has been remapped?
Maybe by knowing the 'standard' readings and then the readings that it would show if it had been mapped in any way shape or form?
Hi,
Anybody know if this is possible?
quite difficult but possible
you could measure max boost and compare it to standard, but many diesel remaps dont change the boost pressure by much at all cos they just need more fuel - and a sticky turbo may give you significantly more boost than anticipated anyway even without a remap.
you could look at the injector fuel flow rates at full throttle but you would need the standard amounts to compare to
for all of these you will need to do some research to find the normal values and the appropriate measuring channel, then measure/compare to what the car has
sorry i cant be more specific
TT-RS 410hp revo
Fiat 500 1.3 tdi 120hp
A3 8P 2.0tdi 240hp Autograph Cars
RS4 B5 520hp MTM
S3 8L 345hp MTM
Volvo 850 T5 300hp BSR
Fiat Punto GT 130hp
Lancia Delta Turbo 185hp
Lancia Beta Coupe 122hp
Mini 74hp
NHN liked this post
You could probably use some logs of the car & work out the bhp, need to ask RT for the blocks to measure & then do some calculations, if its above 140 by some 30+ then its mapped.
Coding, Scanning, Installs, Parts, VCDS Seller
"Live as if you were to die tomorrow, Learn as if you were to live forever"
