DNA TuningJuicy
    edt
    Sep 2011
    Post Thanks / Like
    Replacing / Upgrading Central Electronics Controller Module
    Hi guys,
    I have been trying to make some changes to the 09 Central Electronics controller module but found that the module does not support long coding i.e. it only has a regular (short) code. It is on a 2010 3.0 TDI A6 and I am rather surprised/annoyed that the car has what seems to be such an unusual (dud) module. Everything I have found and read suggests that the CE module supports long coding. This is what the coding screen looks like.
    My current module's part number is 4F0 910 279 N. I am contemplating on replacing/upgrading the module, subject to how difficult it is to do.
    Would anyone be able to advise on:
    1. Where I could search for a list of compatible part number to suit my car? I have looked at genuinevwaudiparts.com but the keyword search does not work properly on that site.
    2. Is it even possible to change from a short (regular) code based module to one that uses long coding? I think the challenge would be to copy the current coding to the new module as the code would be completely different, considering the original code would be short and the new module would require a long code.
    Any insights you may care to share would be appreciated. Thanks.
    18,288
    Post Thanks / Like
    Sort your pic out then we can comment.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    Aug 2006
    Magdeburg, Germany
    286
    Post Thanks / Like
    There has never been a Central Electronics Control Module in the A6 (4F) that supported Long Coding.
    Sebastian @ Ross-Tech.com
  1. B6 CENTRAL ELECTRICS MODULE ( 09 )
    By cheech in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd November 2011, 21:55
  2. Replacing airbag module after a crash
    By Stanley in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd August 2011, 20:21
  3. Module 46 Central Conv - No Response
    By Zeus12 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th May 2011, 17:51
  4. Replacing steering control module.
    By Morten88 in forum General Technical / How To
    Last Post: 5th April 2011, 00:02
