Chris NottVolks Autos
    Aug 2006
    41
    VCDS Fault Codes
    Hi,
    can any body throw some light on these fault codes,i have just started to fit a rear view camera to my A3, i have attached the multi media interface to the connections on the RNS-E and have coded channel 37 navigation to enable viewing when reverse gear is connected ie channel 4 to set from 0 to 1 this seems to be fine but when scanned these faults have come up . Do i also need to tell the navigation that there is a TV tuner as this seems to be looking for this address. should i use the long coding helper on the CAN gateway as this seems to have changed as well.Just to let you know i have RNS-E telephone prep ,CD changer and multi function steering wheel.
    Andy
    Tuesday,23,August,2011,12:51:01:63343
    VCDS Version: Release 10.6.4 (x64)
    Data version: 20110418
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 57 62 72 76
    77
    VIN: WAUZZZ8P05A076898 Mileage: 77070km/47889miles
    19-CAN Gateway -- Status: Malfunction 0010
    37-Navigation -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    57-TV Tuner -- Status: Not registered 0011
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Revision: 08 Serial number: 2500104A0506FA
    Coding: 3D3F07CA072103
    Shop #: WSC 06314 000 00000
    VCID: 28546E98E263
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 22
    Mileage: 77079 km
    Time Indication: 0
    Date: 2011.08.23
    Time: 12:47:21
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 L HW: 8P0 035 192 L
    Component: RNS-E HIGH EU H74 0660
    Revision: 04S Serial number: AUZBZ7G0913898
    Coding: 0215717
    Shop #: WSC 21244 142 61076
    VCID: 3874BED832C3
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 22
    Mileage: 77079 km
    Time Indication: 0
    Date: 2011.08.23
    Time: 12:46:00
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0215717
    VCID: 3874BED832C3
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 22
    Mileage: 77079 km
    Time Indication: 0
    Date: 2011.08.23
    Time: 12:46:00
    Address 57: TV Tuner
    Cannot be reached
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,318
    Maybe pm nigel (NHN) he may be able to help you out with advise.
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
    warren_S3's Avatar
    Oct 2007
    6,093
    Try 0215718
    The last digit 8 Inc. Tv tuner.
    If not then Nige!
    en.openobd.org - radio/navigation systems
    Audi S3 Panther Black [2011] Build Thread
    Mods: Revo Stg2, Blueflame TBE, Eibach Pro springs, R8 oil cap
    On order: Audi S5 3.0V6T Coupe Black Edition, Phantom Black [Due 26 May 2014]
    Planned Mods: Revo Stg1+ with DSG map, Revo CAI, custom exhaust, H&R Trax spacers, EM Tuning LED interior lights, R8 oil cap, Porsche coolant & brake fluid cap
