EM TuningSky Insurance
    Jul 2011
    NW London
    Post Thanks / Like
    VCDS Full scan output...Please help has thrown up many faults
    Hello,
    I got a full scan performed by a forum member who was more than helpful. But neither of us understood the output too well. It has thrown up lots of faults and often the same one appears many times.
    Some faults are time and date stamped whereas others arent..why is this?
    The problem i am trying to resolve is an intermittant drain on the battery where the clocks in the instrument cluster turn on randomly when the car is locked and has been locked for a while. They then stay on until the battery is completely drained.
    I have pasted the output below, and hopefully someone will be able to understand it.
    VCDS Version: Beta 812.4
    Data version: 20090214
    Friday,13,March,2009,19:13:54:26365
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
    VIN: WAUZZZ8P75A082360 Mileage: 71570km/44471miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: Sporadic communication error 1000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: Malfunction 1010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 1010
    62-Door,Rear Left -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: Malfunction 0010
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 03C 906 056 AP HW: Hardware No
    Component: MED9.5.10 00 7000
    Revision: 00000000 Serial number: AUX7Z0DNFN10DT
    Coding: 0000072
    Shop #: WSC 06314 000 00000
    3 Faults Found
    16580 - Engine Oil Temp. Sensor (G8): Implausible Signal
    P0196 - 004 - No Signal/Communication
    18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
    P1650 - 008 - Implausible Signal - Intermittent
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 008 - Implausible Signal - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0104
    Coding: 0019077
    Shop #: WSC 06435 000 00000
    No fault code found.
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 F HW: 8P0 820 043 F
    Component: KlimavollautomatH13 0150
    Revision: 015040 Serial number: 8P0820043F
    2 Faults Found
    01274 - Air Flow Flap Positioning Motor (V71)
    003 - Mechanical Failure - Intermittent
    Freeze Frame:
    Fault Status: 00100011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 135
    Mileage: 70570 km
    Time Indication: 0
    Date: 2011.06.03
    Time: 19:06:21
    Freeze Frame:
    Voltage: 12.40 V
    Temperature: 31.0°C
    (no units): 192.0
    (no units): 33.0
    Temperature: 21.5°C
    01317 - Control Module in Instrument Cluster (J285)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 151
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    ON
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
    Component: Bordnetz-SG H34 0301
    Revision: 00H34000 Serial number: 00000001208363
    Coding: 058C4F02B014100000160000160000000000FE0F5C
    Shop #: WSC 00000 000 00000
    Part No: 8P2 955 119 B
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 00000
    3 Faults Found
    00988 - Lamp for Brake Light; Right (M10)
    012 - Electrical Fault in Circuit
    00987 - Lamp for Brake Light; Left (M9)
    012 - Electrical Fault in Circuit - Intermittent
    00446 - Function Limitation due to Under-Voltage
    002 - Lower Limit Exceeded - Intermittent
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
    Component: Airbag 9.41 H10 2620
    Revision: 91H10262 Serial number: 003620010NNF
    Coding: 0034622
    1 Fault Found
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 211
    Mileage: 0 km
    Time Indication: 0
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
    Component: Lenksäulenmodul 012 0030
    Coding: 0000012
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 980 T HW: 8P0 920 980 T
    Component: KOMBIINSTR. VDO H73 0300
    Revision: D04 Serial number: 224NDD04000558
    Coding: 0004443
    Shop #: WSC 01179 210 93569
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Revision: 08 Serial number: 2500104A2505A1
    Coding: 3D3F0342072103
    5 Faults Found
    00466 - Control Module for Steering Column Electronics (J527)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 143
    Mileage: 71028 km
    Time Indication: 0
    Date: 2011.06.23
    Time: 00:00:08
    00381 - Databus Instrument Cluster
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 1
    Fault Frequency: 6
    Reset counter: 151
    01304 - Radio
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 143
    Mileage: 71028 km
    Time Indication: 0
    Date: 2011.06.23
    Time: 00:08:18
    00463 - Control Module for Digital Sound Package (J525)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 143
    Mileage: 71028 km
    Time Indication: 0
    Date: 2011.06.23
    Time: 00:08:44
    01305 - Databus for Infotainment
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 3
    Reset counter: 143
    Mileage: 71028 km
    Time Indication: 0
    Date: 2011.06.23
    Time: 00:09:14
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D04 Serial number: AUX7Z0DNFN10DT
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
    Part No: 8P0 959 801 E
    Component: Tuersteuerger. H10 0030
    Coding: 0000120
    1 Fault Found
    01811 - Supply Voltage for Door Controller; Drivers Side (J386)
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 H
    Component: EPS_ZFLS Kl.7 1502
    1 Fault Found
    00750 - Warning Lamp
    013 - Check DTC Memory - MIL ON
    Freeze Frame:
    Mileage: 7160 km
    Temperature: -1.0°C
    Voltage: 11.70 V
    Voltage: 11.50 V
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 C
    Component: KSG H04 0050
    Coding: 188000186D088505489FC63000
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H02 1301
    Part No: 1K0 907 719 B
    Component: Neigungssensor 004 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0020
    2 Faults Found
    00926 - Terminal 30
    011 - Open Circuit - Intermittent
    01299 - Diagnostic Interface for Data Bus (J533)
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 HW: 8P4 035 382
    Component: AB2 SUBWOOFERBOXH03 0180
    Revision: 00002 Serial number: 10000001207374
    2 Faults Found
    00532 - Supply Voltage B+
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 7
    Fault Frequency: 3
    Reset counter: 154
    Mileage: 70800 km
    Time Indication: 0
    Date: 2011.06.12
    Time: 13:48:44
    Freeze Frame:
    Temperature: 17.0°C
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 3
    Reset counter: 154
    Mileage: 70800 km
    Time Indication: 0
    Date: 2011.06.12
    Time: 13:48:05
    Freeze Frame:
    Temperature: 17.0°C
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
    Part No: 8P0 959 802 E
    Coding: 0000120
    1 Fault Found
    01812 - Supply Voltage for Door Controller; Pass. Side (J387)
    Address 56: Radio Labels: 8P0-035-1xx-56.lbl
    Part No SW: 8P0 035 195 HW: 8P0 035 195
    Component: symphony II EU H57 0410
    Revision: 22S Serial number: AUZ5Z4D6047920
    Coding: 0001001
    3 Faults Found
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 151
    Freeze Frame:
    Bin. Bits: 00
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 3
    Reset counter: 154
    Mileage: 70800 km
    Time Indication: 0
    Date: 2011.06.12
    Time: 12:48:59
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 143
    Mileage: 71044 km
    Time Indication: 0
    Date: 2011.06.23
    Time: 05:25:21
    Address 62: Door,Rear Left Labels: 8P4-959-801.lbl
    Part No: 8P4 959 801 B
    Component: Tuer-SG H10 0010
    Coding: 0000216
    3 Faults Found
    01813 - Supply Voltage for Door Controller; Rear Left (J388)
    00934 - Electric Window Motor; Rear Left (V26)
    005 - No or Incorrect Basic Setting / Adaptation
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No: 8P4 959 802 B
    Coding: 0000216
    1 Fault Found
    01814 - Supply Voltage for Door Controller; Rear Right (J389)
    18,288
    Post Thanks / Like
    Most are due to battery being flat, get car running & then scan/clear & see whats left as most will go when battery is charging.
    I would check door lock, battery state, disconnect radio & see if issues goes away as this has a known battery drain issue, hazard switch, numerous things could cause this.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
