hi all, not been on for a while, maybe someone could help me out here.
my brother in law has bought an 06 plate vw eos, it has a fault that there is no washers on front windscreen.
heres the scan
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Control Module Part Number: 3C0 937 049 Q HW: 3C0 937 049 Q
Component and/or Version: Bordnetz-SG H46 1501
Software Coding: E5069E0700041500470A00000F00000000095D035C0000
Work Shop Code: WSC 00020 000 00000
Additional Info: 1K2955119E Wischer 120606 020 0501 1K0955559AE RLS 250506 014 1201
VCID: 37794E753FCB
2 Faults Found:
00156 - Control Circuit for Windshield Washer Pump
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 157
Mileage: 57483 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.80 V
ON
ON
OFF
OFF
OFF
02390 - Control / Regulation for Ambience Lighting (E400)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 157
Mileage: 57483 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.80 V
ON
ON
OFF
OFF
OFF
in measuring blocks its showing that the stalk is talking and showing readings as it should, at the central electrics module, i can supply 12v directly to the plug and washer bottle kicks in.
all fuses and relays etc are fine.
with the headlights on the headlight washers work fine from the same stalk.
LinkBack URL
About LinkBacks
cab
