DPMRevo Technik
    Jun 2011
    39
    Post Thanks / Like
    VCDS-lite 2002 A3 "Not OBD II Compatible"
    Hi,
    Keep getting this error on my A3 Tdi?
    I've check the drivers are installed...and its also on the correct com port.
    When it scans it goes through everything the comes up "End Test" but with o results etc??
    Then when doing the compatibility test it comes up with the above error?
    Any ideas?
    I'm using an ebay cable with VCDS-lite (also tried it on the older version of Vag Com) with windows vista.
    Phil
    Jun 2011
    39
    Post Thanks / Like
    ok..well I've found a bit more info and the OBD II bit should not result in it not scanning?
    Any ideas why it won't scan?
    Drivers are ok...serial port is ok..lead into car. Ignition is on.
    18,288
    Post Thanks / Like
    Can you access a module directly instead of an auto scan
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    Jun 2011
    39
    Post Thanks / Like
    No, Comes up with some error saying it cannot see the module or something?
