DTUKEM Tuning
    10
    Post Thanks / Like
    Engine running problem
    Hello all apologies in advance if I sholdnt be posting here,
    was recently removing my wiper motor/linkages and had to remove the electrical connections (4 plugs and one power supply wire) in the pledum chamber going down inside behind the steering colum. I did not have the ECU disconnected just the connectons in the box. here are the conditions all this happened under:
    battery was still connected the whole time, (was just 100% lazy) might have cost me
    ignition off when disconnecting but was turned on when disconnected to move wipers
    whats happening now basically is limp mode and running rough, not nice when its remapped!
    egr faults
    charge pressure faults
    and a few other faults.
    i have vdcs so if anyone has more knowledge of a few things I could try check ill look forward to it.
    cheers people
    a4 03 1.9tdi 130 avf
    18,288
    Post Thanks / Like
    Post the logs so we can see what you're referring to.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    10
    Post Thanks / Like
    Tuesday,28,June,2011,12:18:49:13314
    VCDS Version: Release 908.0
    Data version: 20090911
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E74A051462 Mileage: 160830km/99935miles
    Address 01: Engine Labels: 038-906-019-AVF.lbl
    Part No: 038 906 019 LJ
    Component: 1,9l R4 EDC G000SG 4910
    Coding: 00002
    Shop #: WSC 63351
    WAUZZZ8E74A051462 AUZ6Z0C0194512
    2 Faults Found:
    19586 - EGR System: Regulation Range Exceeded
    P3130 - 35-10 - - - Intermittent
    17964 - Charge Pressure Control: Negative Deviation
    P1556 - 35-00 - -
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517
    Component: ABS/ESP front 3429
    Coding: 04255
    Shop #: WSC 06435
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AA
    Component: A4 Klimaautomat 1219
    Coding: 00000
    Shop #: WSC 63351
    1 Fault Found:
    00601 - Potentiometer On Positioning Motor for Central Flap (G112)
    30-10 - Open or Short to Plus - Intermittent
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 E
    Component: int. Lastmodul RDW 0305
    Coding: 00001
    Shop #: WSC 63351
    No fault code found.
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 B
    Component: Airbag 8.4EP 3002
    Coding: 0010602
    Shop #: WSC 63351 000 00000
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 N
    Component: Lenksáulenmodul 0308
    Coding: 00041
    Shop #: WSC 63351
    1 Fault Found:
    01317 - Control Module in Instrument Cluster (J285)
    49-10 - No Communications - Intermittent
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 J
    Component: KOMBI+WEGFAHRS. RB4 D37
    Coding: 00400
    Shop #: WSC 00409
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0604
    Coding: 00001
    Shop #: WSC 00000
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BC
    Component: Komfortgerát T3B 1311
    Coding: 07883
    Shop #: WSC 63351
    Part No: 8E2959802B
    Component: Tõrsteuer.FS BRM 0003
    Part No: 8E2959801B
    Component: Tõrsteuer.BF BRM 0003
    Part No: 8E0959801A
    Component: Tõrsteuer.HL BRM 0003
    Part No: 8E0959802A
    Component: Tõrsteuer.HR BRM 0003
    2 Faults Found:
    00956 - Key 2
    01331 - Door Control Module; Driver Side (J386)
    80-00 - Single-Wire Operation
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 186 J
    Component: concert II GRO 0008
    Coding: 01001
    Shop #: WSC 63351
