Tuesday,28,June,2011,12:18:49:13314
VCDS Version: Release 908.0
Data version: 20090911
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E74A051462 Mileage: 160830km/99935miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 LJ
Component: 1,9l R4 EDC G000SG 4910
Coding: 00002
Shop #: WSC 63351
WAUZZZ8E74A051462 AUZ6Z0C0194512
2 Faults Found:
19586 - EGR System: Regulation Range Exceeded
P3130 - 35-10 - - - Intermittent
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-00 - -
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04255
Shop #: WSC 06435
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AA
Component: A4 Klimaautomat 1219
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
00601 - Potentiometer On Positioning Motor for Central Flap (G112)
30-10 - Open or Short to Plus - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63351
No fault code found.
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 B
Component: Airbag 8.4EP 3002
Coding: 0010602
Shop #: WSC 63351 000 00000
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0308
Coding: 00041
Shop #: WSC 63351
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 J
Component: KOMBI+WEGFAHRS. RB4 D37
Coding: 00400
Shop #: WSC 00409
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BC
Component: Komfortgerát T3B 1311
Coding: 07883
Shop #: WSC 63351
Part No: 8E2959802B
Component: Tõrsteuer.FS BRM 0003
Part No: 8E2959801B
Component: Tõrsteuer.BF BRM 0003
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0003
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0003
2 Faults Found:
00956 - Key 2
01331 - Door Control Module; Driver Side (J386)
80-00 - Single-Wire Operation
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186 J
Component: concert II GRO 0008
Coding: 01001
Shop #: WSC 63351
