Hi Hopefully someone will be able to give me some guidance.
I have carried out a cambelt change on the above vehicle and the EML has come on afterwards. Thinking there was something wrong with the timing I have checked and re-checked this and all is good.
Scanning the car shows code 17524 - Oxygen (Lambda) sensor heating bank 1 sensor 1 - Open circuit. I have printed the test procedure off Autodata and followed that. All seems to be ok apart from the supply voltage for the heater which Autodata is saying should be between 11 & 14 volts. It is a constant 4.1 volts.
Can you advise what controls this supply voltage? Is it direct from the ECU or via a fuse in the fuse box.
I have been in this car for a LONG time and would like to get it sorted please...
Many thanks for any help or advice you can give
Jason
LinkBack URL
About LinkBacks
