Adrian S FluxBackdraft Motorsport
Results 1 to 8 of 8
    Rossy's Avatar
    Feb 2011
    93
    Post Thanks / Like
    2001 Allroad A6 TDI 2.5 180 Engine Check Light
    Can this be "turned off" perminantly as mine does not come on at all?
    Yet doing a Dash test it lights up?
    Whats going on?
    Rossy
    Rossy's Avatar
    Feb 2011
    93
    Post Thanks / Like
    No one?
    Jul 2007
    London
    1,574
    Post Thanks / Like
    If it doesnt come on it means the car's engine is in good working order. The emission light on the c5 audi a6/allroad doubles as the coil light on the dash. When the engine has a problem the glow plug light is flashing...
    FOR SALE:
    Rossy's Avatar
    Feb 2011
    93
    Post Thanks / Like
    So audi's are differant to other cars? Usualy the engine check light come on before you start the car then goes off. Mine does not come on at all ever!! (unless you do an instruments test then it lights up with the rest of the lights)
    Jul 2007
    London
    1,574
    Post Thanks / Like
    A6/allroad is quite a old platform and it does not have all the emission restrictions like the new cars have wich will trigger limp mode everytime the breeze is blowing from north ! You should worry less and enjoy the car more. The car will let you know when she's not right !
    FOR SALE:
    Rossy's Avatar
    Feb 2011
    93
    Post Thanks / Like
    Yeh next one is sorting the suspension out after it all being renew'd. Its and inch hight front and rear passanger side than it is drivers side..
    Jul 2007
    London
    1,574
    Post Thanks / Like
    I would check/replace the level sensors on that side, they can cause the height difference. It could also be down to the valve body, they known to seize in some cases...
    FOR SALE:
    Rossy's Avatar
    Feb 2011
    93
    Post Thanks / Like
    I think its because the garage didn't put it in Jack mode...it raises and lowers equaly all round but inch higher on passanger side.
    Is there a way to con it back to norm? i.e. put in jack mode then jack the drivers side, then take out of jack mode or similar?
    Going to mates tomorrow to try the 402 MOD via vag com...lets hope its summat simple like it just need a reset!
    Once this is done, just two weeping injectors and thats it I hope for now......
