Sky InsuranceW8 Performance
Results 1 to 24 of 24
    May 2011
    12
    Post Thanks / Like
    VCDS Security Access Code - Audi A1?
    Hey guys,
    I am trying to get into some settings in VCDS to change the brightness of my DRLs on my Audi A1.
    It is asking for a security access code... From a bit of research normally there should be a pop up bubble that tells you the number, but this doesn't happen.
    Does anyone know how to find the code or does anyone know it?
    Thanks.
    18,288
    Post Thanks / Like
    What version number of vcds are you using & is it genuine or counterfeit?
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    May 2011
    12
    Post Thanks / Like
    10.6.3
    18,288
    Post Thanks / Like
    & the rest of the question?
    May 2011
    12
    Post Thanks / Like
    I am not sure, as i have borrowed the cable to change settings.
    18,288
    Post Thanks / Like
    May 2011
    12
    Post Thanks / Like
    Ok thanks, i will try that.
    May 2011
    12
    Post Thanks / Like
    Still no go... It is a authentic cable by the way.
    18,288
    Post Thanks / Like
    Please show us a screen shot of the page where its asking for security code.
    May 2011
    12
    Post Thanks / Like
    Will that be able to tell you the code?
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,084
    Post Thanks / Like
    If it did I'm sure NHN would have told you. Need to see where you're looking for the access code.
    If the 'bubble' hasn't popped up with the code, you're either not supposed to know it or RT havent had their hands on the module yet to map it.
    Audi A3 2.0TFSI S Line SE DSG
    Cruise Control | Ambient Lights | LED Lighting | Full Leather | RNS-E MK2
    OEM Bluetooth | AUX | CH/LH Lights | MFSW | S3 Pedals | BFT Remap
    JMB Retrofits - North East Retrofit Company
  13. Likes NHN liked this post
  14. #12
    18,288
    Post Thanks / Like
    Please show us the screen dump.
  15. #13
    Apr 2011
    195
    Post Thanks / Like
    you need to screen dump what your doing so it can be seen and help given
    post a dump of address 09 long code and adaptation channels etc
  16. Thanks NHN thanked for this post
  17. #14
    Apr 2011
    195
    Post Thanks / Like
    Go to address 09
    Long code helper
    Change byte 24 for drl dimming
    Sent from my iPhone using
    My fat fingers
  18. Thanks jb0o thanked for this post
  19. #15
    Oct 2011
    Brazil
    Post Thanks / Like
    Hi NHN, im searching for the codes to unlock vim on my Audi A1. In Advanced ID doesnt appear tge serial number to insert in the software created by trick 77. Can you help me to find the codes for security acess?
    Thanks a lot
  20. #16
    Oct 2011
    Brazil
    Post Thanks / Like
    Dear NHM im trying to find a way to unlock vim on my Audi A1 - Can you help me? Im using an original VCDS cable and software. Thanks a lot.
  21. #17
    18,288
    Post Thanks / Like
    Show me a log of your car please.
  22. #18
    h5djr's Avatar
    Cambs, UK
    5,293
    Post Thanks / Like
    Another item in connection with VCDS on the A1.
    With the A3 it is possible to change the instrument lighting using module 17 Instruments and changing the last digit of the seven digit code to a 4. This gives Needles ON Scales ON.
    The list of options with the seven digit code are:
    xxxxx?x
    0 = Seatbelt Warning Inactive
    xxxxxx?
    0 = Needles OFF and Scales Off
    1 = Needles ON and Scales Off
    2 = Needles OFF and Scales ON
    3 = Needles ON and Scales ON (Dimming active)
    4 = Needles ON and Scales ON
    Does anyone have access to an A1 and the correct cable to check if this works on the A1. We have taken the car to the dealers and they could not work out how to do it!!. The also contacted Audi UK who said it could not be done, but it seems to use the same J285 module to control the instruments as the A3. Maybe they are right but it would be rather nice to prove them wrong and get it to work.
    Dave R (h5djr)
    A3 8P3 2.0 TDI-170 Sportback SE S-tronic - Silver + loads of options - my 8th A3
  23. #19
    Feb 2012
    Post Thanks / Like
    Audi A1 Access code problem
    Hey guys,I am trying to get into some settings in VCDS to change the brightness of my DRLs on my Audi A1.
    The version number of vcds is 11.2
    And my cable is authentic.
    Thanks.
  24. #20
    Feb 2012
    Post Thanks / Like
    Hey guys,
    My vcds version number is 11.2
    and my cable is athentic.
    Thanks for your help
  25. #21
    gary3306's Avatar
    Oct 2010
    Northumberland
    839
    Post Thanks / Like
    3 posts from Nigel asking for a screen dump of the log. I have a sneaky feeling he might not post in this thread again........
    Suzuki GSX-R 750 K6
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
  26. Thanks NHN thanked for this post
  27. #22
    18,288
    Post Thanks / Like
    & again, I like to help where I can, but you have to help yourselves please, POST A SCREEN DUMP of the said warning & log of your car, that way it provides us with allot more info to be able to look into the issues.
  28. #23
    Feb 2012
    Post Thanks / Like
    Scuse me NHN but i don't understand...
    Do you want an image as this?
    I wait your notices
  29. #24
    Feb 2012
    Post Thanks / Like
    Pictures by AudiA1Peppe - Photobucket
    My Car is an AUDI A1 1.6 TDi year 2010
    I wait your notices
