So i have just installed 2009 rear lights to my sportback .I have got a couple of errors .I have lost touch with the errors and where to find the answers .Any ideas whats wrong ?
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AD HW: 8P0 820 043 AD
Component: KlimavollautomatH19 0360
Revision: 050152 Serial number: 8P0820043AD
Shop #: WSC 06314 000 00000
1 Fault Found
00716 - Air recirculation Flap Positioning Motor (V113)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 91
Reset counter: 129
Mileage: 134663 km
Time Indication: 0
Date: 2011.02.21
Time: 15:30:30
Freeze Frame:
Voltage: 14.30 V
Temperature: 8.0°C
(no units): 215.0
(no units): 136.0
Temperature: 5.0°C
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0090
Coding: 0000688
1 Fault Found
00913 - Window Regulator Switch; Front Right Driver (E81)
008 - Implausible Signal - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.078 H07 1806
Shop #: WSC 02069 000 90108
No fault code found.
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 F
Component: KSG H05 0070
Coding: 9980202002186D098505489FC637
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
1 Fault Found
00956 - Key 2
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
LinkBack URL
About LinkBacks
Robin Reliant
so fingers crossed ..
