EM TuningDTUK
Results 1 to 9 of 9
    Jan 2011
    Aberdeenshire
    213
    Post Thanks / Like
    Engine Adaptions Login
    I was looking to log into my engine ECU to try and adjust the EGR, but I keep getting communication errors. I have no such problem with any other of the many parameters I have tried so far, so don't really know where to start.
    I have a genuine Ross-Tech KII interface, using the new VCDS (can't remember version, downloaded the updated 10.?? the other week), I am trying 12233 as the login code, although I am aware this may not be correct for my car.
    I'm trying it on a 2000 plate A4, 2.5 TDi Quattro
    I haven't posted on Ross-Tech yet, but have had a look through the site and can't see anything that might help (sorry Bear!)
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    Jan 2011
    Aberdeenshire
    213
    Post Thanks / Like
    Ummm,
    I'll reply to myself as the answer was in the question!
    Having done a bit more research (Google is your friend!) I think that I need to use the code 26262 to log into the AFB, as the 12233 code is for the 1.9.
    I did find a post from Adamss24 on a different site back in 2006 asking the same thing did you ever get anywhere?
    I'll try again when I'm on days off, and post results for others.
    Meanwhile if anybody can confirm the login for an AFB engine, I would appreciate it.
    18,288
    Post Thanks / Like
    If you have a genuine interface, ping an email to support@ross-tech.com & they will advise if they are aware.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    Jan 2011
    Aberdeenshire
    213
    Post Thanks / Like
    Thanks Nigel,
    I'll do that once I start looking into it again on Monday as I have a genuine KII interface from them.
    BTW, do you do a similar money off deal if upgrading to a K and CAN lead? (Am I allowed to creep my own thread?)
    Jan 2011
    Aberdeenshire
    213
    Post Thanks / Like
    Ok, to finish up:
    To log into a 2000 A4 2.5 TDi AFB engine for EGR adjustment, the code is 26242. I changed the value in block 3 from 32768 to 33668 (the suggested 33768 was too high a value)
    If the wrong code is entered, communication is lost with 'too many errors to continue' after a while. Switch off ignition, then try again with the correct code.
    18,288
    Post Thanks / Like
    Quote Originally Posted by PAULF View Post
    Thanks Nigel,
    Sorry mate I dont offer upgrades, this is solely done via the RT website iirc, but may I suggest offloading yours probably for the difference in the 2 adapters, I can sell you hex-can-usb anytime mate.
    Jan 2011
    Aberdeenshire
    213
    Post Thanks / Like
    Thanks Nigel,
    I'll give you a shout when I change, K-Line is good enough for my B5s at the moment!
    Paul
    18,288
    Post Thanks / Like
    No worries mate, wish could of helped more, but because the clone wars & counterfeits, this has forced RT to encrypt the label files which quite rightly so, so I cant even look at these to see what any login codes are for certain cars. yours may have access still of the car, but you need to be plugged into allot of cars these days to see what the files state.
    tdi-man's Avatar
    Jul 2009
    990
    Post Thanks / Like
    any idea on adaption login code for a3 2005 tdi ?
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium door inlays / panal filter / Egr delete / custom map with hot start fix + warm idle fix / Hybrid Turbo / Helix clutch / 12mm Rear spacers / 10mm Front spacers
    213 bhp - 294 ft lb - 399 nm
    Wifes car - Mk4 Golf GT TDI 150 - 18s - remapped
    FOR SALE
    TANDEM PUMP
