EM TuningDNA Tuning
    May 2011
    Post Thanks / Like
    Parking sensor fault diagnosis with VCDS lite registered?
    Hi,
    I have VCDS lite registered version. I'm a new novice user and really only bought it to diagnose the occasional fault.
    My parking sensors have stopped working, they were intermittent. The fault code I get is 01549 - supply voltage for parking aid sensor. 29-00 - short to ground.
    When I try and use the measuring blocks in VCDS, I don't seem to get anything to show movement from the sensors? I want to try and pinpoint which sensor is not working but I'm not sure how?
    Can anyone please explain how to do this?
    Whitey
    Car is 2005 Allroad 4.2 (C5)
    18,288
    Post Thanks / Like
    Check its plugged in 1st as they have been known to have connectors slip of, also are you saying vcds is registered with a license with RT, if so you're entitled to support from them directly, so ping them an email.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
