W8 PerformanceGNJ
Results 1 to 7 of 7
Thread: Fault Code help
    way318's Avatar
    Jan 2009
    Merseyside
    155
    Post Thanks / Like
    Fault Code help
    Hi, does any one know what causes this fault code :- 01314 - Engine Control Module - No Communication.
    bearthebruce's Avatar
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    291
    Post Thanks / Like
    Here are some ideas on the Ross-Tech Wiki: 01314
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
  4. Thanks way318 thanked for this post
  5. #3
    18,288
    Post Thanks / Like
    Have you done or had done any work to the car of late?
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
  6. #4
    way318's Avatar
    Jan 2009
    Merseyside
    155
    Post Thanks / Like
    Not as far as I know, as it was a mates car with the fault code.
    He took into a VW/Audi specialist, they checked it over and told him he needs a new cluster @ £645.
    Not sure the price of these, but that does seem expensive.
  7. #5
    18,288
    Post Thanks / Like
    Huh, so the fault was comms with ecu & they then denoted cluster needs changing, what car was this on as wanna check if the cluster is the gateway for comms to ecu as this is only reason I know of to change cluster, then again if it controls network for other modules these may fault aswell, but limited info from you isnt helping the fault find mate, can you advise anything else, like car, year, etc etc.
  8. #6
    way318's Avatar
    Jan 2009
    Merseyside
    155
    Post Thanks / Like
    Hi mate, it was a A4 56 Plate 07MY B7 Avant 2.0 TDI (170).
    Spoke to my mate today and he said that the garage said the only way they could get the car to start was to remove the 10A fuse for the cluster and the put it back in. After he got the price off the garage he spoke to Audi about the cluster problem and they have told him its a common problem with his model and are willing to do a deal on getting it resolved, so he got it booked into his local dealer this week.
    Will let you know how he gets on.
  9. #7
    18,288
    Post Thanks / Like
    Thanks for letting us know.
