Backdraft MotorsportGNJ
Like Tree1Likes
  • 1 Post By bearthebruce
Thread: using VCDS Lite
    Dec 2010
    12
    Post Thanks / Like
    using VCDS Lite
    Just wondering if anybody knows if an engine check light or fault is cleared by using VCDS lite/Vagcom then the fault reappears dose vagcom log how many miles it took for fault to reappear
    bearthebruce's Avatar
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    291
    Post Thanks / Like
    No it does not log the miles between faults. VCDS - not the lite product - may show the mileage at which a fault occurs if the ECU being monitored has this information. Not all modules do.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    18,288
    Post Thanks / Like
    Can you expand on why you would need this function anyway, just curious, any specific module you want to monitor for longevity?
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    Dec 2010
    12
    Post Thanks / Like
    i'm just being curious when i bought the car it had a vac leak which put MIL on so dealers mechanic cleared the fault and off i went the MIL lamp came on again a few days later and his handheld scanner showed it took 15 km for the fault to return so was just wondering if VCDS had this function
    Kind regards
    Garber
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    291
    Post Thanks / Like
    If the tool he used can read what is known as the freeze frame data, and if the guy had marked previous mileage, he could know the difference between first occurrence and the second occurrence. VCDS does show the freeze frame data. See the on line manual.
    Garber likes this.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
  7. Thanks Garber thanked for this post
