Badger5Juicy
    Lloyd149's Avatar
    Dec 2009
    York
    102
    Post Thanks / Like
    Audi A2 fault code - 00588 - Drivers Airbag Igniter
    00588 - Ross-Tech Wiki
    The fault logged, is saying the Airbag Igniter (N95) on driver's side resistance is too high.
    Would I be right in thinking this is probably down to faulty wiring, if not the igniter itself has broken.
    How easy is the task in hand to get to the igniter? Where about's is it?
    Any help much appreciated.
    18,288
    Post Thanks / Like
    If this is a seat airbag, check wiring underneath the seat, these on some vag cars, can become disconnected.
    Dont try & clear it without checking the wiki advice as it could ignite.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
