EM TuningRevo Technik
    Aug 2008
    37
    Post Thanks / Like
    How do I test N80 Evap Purge valve?
    Anyone explain to a noobie how I should go about testing the N80 valve using VCDS? . Car is a 2008 Audi TT 8J
    Der_Techniker's Avatar
    Foursprung Duck Technique
    Oct 2010
    Coventry, West Midlands
    1,003
    Post Thanks / Like
    01-Engine, Select 03-Output tests and its the 1st or second item iirc, should hear/feel it clicking.
    2000 Silver Audi A4 1.8T Sport, With added Carbon Goodness
    "Arguing with an engineer is a lot like wrestling in the mud with a pig. After a few hours, you realize that he likes it."
  4. Thanks Dana @ Ross-Tech thanked for this post
  5. #3
    Oct 2009
    46
    Post Thanks / Like
    In addition to the Output testing KOEO (Key On, Engine Off) this should support running Basic Settings while running and test the Evap system to confirm a problem or verify the repair. Post the scan data if you need help with the group numbers, or see if the EOL 200 test will run:
    2.0l TFSI (AXX/BGB/BPJ/BPY/BWA) - Ross-Tech Wiki
