How do I test N80 Evap Purge valve?
PiloTT
NULL
Anyone explain to a noobie how I should go about testing the N80 valve using VCDS? . Car is a 2008 Audi TT 8J
01-Engine, Select 03-Output tests and its the 1st or second item iirc, should hear/feel it clicking.
In addition to the Output testing KOEO (Key On, Engine Off) this should support running Basic Settings while running and test the Evap system to confirm a problem or verify the repair. Post the scan data if you need help with the group numbers, or see if the EOL 200 test will run:
2.0l TFSI (AXX/BGB/BPJ/BPY/BWA) - Ross-Tech Wiki
