JBSVAG Check
Like Tree1Likes
  • 1 Post By markie A3
Thread: aircon
    Feb 2011
    Leeds
    149
    Post Thanks / Like
    aircon
    I know theres a specific air con section, but ive asked this question already..
    Will Vcds detect if the compressor isnt running, my aircon isnt blowing cool/cold air at all. I'm not really sure what kind of noise the compressor makes so a noise test isnt much help. AOnce again sorry to ask in the vcds section
    Thanks Mark
    Apr 2011
    195
    Post Thanks / Like
    yes look in address 08 open label file look at compressor draw amperage for operation
    a/c gauges are better for diagnosis but mvb will show you whats going on and the system pressure as well from the readings at the pressure switch
  4. Thanks markie A3 thanked for this post
    Likes markie A3 liked this post
  5. #3
    Feb 2011
    Leeds
    149
    Post Thanks / Like
    Thanks a8 tech......
    If its not running/faulting, will it show as a fault when the car is scanned?
  6. #4
    Apr 2011
    195
    Post Thanks / Like
    unlikely unless you have low pressure because the comp is duty cycled so the signal will still go as the a/c pulley anti seize pulley breaks away if the pump is foobar.
    Check the line pressure in the mvb, even with the a/c off then there should be some pressure
    If you have sufficient pressure but the a/c will not start up without a fault code and the amperage stays constant then it normally indicates the pump but at this stage if pressure is present I would connect the a/c gauges to see a more in depth status
  7. #5
    Feb 2011
    Leeds
    149
    Post Thanks / Like
    Thanks for you help fella
    deleted likes this.
  8. #6
    Apr 2011
    195
    Post Thanks / Like
    no worries hope it makes sense
