Some A4 B7 Tweak questions
benr
Hi,
Playing with my VCDS in my A4 B7 I'm looking for things to play with.
I have enabled the lights icon in the cluster as I missed it from my A3 but thats all i have found that I can do.
Few questions:
Firstly - I was able to enable speed showing in the symphony 2+ however it only shows as kph. anyway to change this to mph? i tried to change the last digit to another country code but it kept refusing the coding.
Can I:
1-Tilting mirror when put into reverse.
2-Needle sweep on start up - Guessing not possible
3-Removing/Adding DRL's of any kind - Fogs as DRL would be good. I tried changing the location to canada but it put indicators as DRL
4-Activate TPMS
5-upshift indicator in dis (efficiency programme) - its in my user manual but cant find how to enable it
6-Fog lights as cornering lights
As the B7 does not support long coding it seems quite limited.
Anything else?
Ben
