VAG CheckBadger5
    tdi-man's Avatar
    Jul 2009
    991
    Post Thanks / Like
    how to turn tick over up
    any body know how to turn idle up ?
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium door inlays / panal filter / Egr delete / custom map with hot start fix + warm idle fix / Hybrid Turbo / Helix clutch / 12mm Rear spacers / 10mm Front spacers
    213 bhp - 294 ft lb - 399 nm
    Wifes car - Mk4 Golf GT TDI 150 - 18s - remapped
    FOR SALE
    TANDEM PUMP
    Fossie
    2,746
    Post Thanks / Like
    Quote Originally Posted by tdi-man View Post
    Yep - I did a write up about this some 6-9 months ago !
    I'll see if I can find it !
    EDIT - here it is :-
    This is for version 908 :-
    Ignition on - engine off
    Select Engine controller 01
    Select Measuring blocks 08
    Select 'Go' in Group 1
    Start Engine ( you may be able to start engine earlier but I don't )
    Hit 'Turbo' button at top of page
    Select 'Done'
    Select Adaptation - 10
    Change channel to 06 and hit 'Read'
    First figure shows actual rpm
    Stored value shows rpm as originally set ( mine is 840 )
    New value will show same figure
    Use up/down buttons to change revs and when happy press 'Test' to see if ok
    If ok then hit 'Save' and close otherwise fiddle around with revs and test until happy.
  4. Thanks martinivw thanked for this post
    Likes martinivw liked this post
  5. #3
    martinivw's Avatar
    Jul 2008
    TheShire
    209
    Post Thanks / Like
    Select 'Done'
    If like me you are bothered with rough idle/tickover use mikes guide to turn revs DOWN,
    yes that's right turn them down for a while I have been turning mine up (thanks Ewan)with little improvement, to my surprise I have just
    turned rpm down to 800 rpm with INSTANT improvement ,
    It has only been 10 mins so I guess time will tell
Tags for this Thread
