W8 PerformanceEM Tuning
    May 2009
    46
    Post Thanks / Like
    01314 - Engine control module problems - help?
    Folks - have jumped over from the A3 8P forum, hope someone can shed some light on this VCDS scan.
    The 1.9tdi Sportback is cutting out going over bumps - have checked physical connections etc. The scan my mate performed below reveals the repeated 01314 code regarding the engine control module - could this be causing the problem?
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 7D
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Sporadic communication error 1000
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door,Rear Left -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Part No SW: 03G 906 016 CC HW: 028 101 183 2
    Component: R4 1,9L EDC 0000SG 6231
    Revision: 12345678 Serial number: AUX7Z0D9FND0BK
    Coding: 0000071
    Shop #: WSC 06314 000 00000
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
    Part No: 1K0 907 379 N
    Component: ASR FRONT MK70 0103
    Coding: 0017025
    Shop #: WSC 06435 000 00000
    1 Fault Found:
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
    Component: KlimavollautomatH12 0150
    Revision: 105846 Serial number: 8P0820043D
    1 Fault Found:
    00819 - High Pressure Sensor (G65)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 198
    Reset counter: 119
    Mileage: 226825 km
    Time Indication: 0
    Date: 2010.09.18
    Time: 21:59:02
    Freeze Frame:
    Temperature: 4.5°C
    Voltage: 12.10 V
    RPM: 0 /min
    Load: 0.0 %
    Load: 9.0 %
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
    Component: Bordnetz-SG H34 0301
    Revision: 00H34000 Serial number: 00000001126281
    Coding: 01884F02B214100000160000160000000000FE0F5C
    Shop #: WSC 00000 000 00000
    Part No: 8P2 955 119 B
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 00000
    3 Faults Found:
    02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
    00188 - Control Circuit 1; Relay for Supply Voltage Terminal 50
    010 - Open or Short to Plus - Intermittent
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
    Component: Airbag 9.41 H10 2620
    Revision: 91H10262 Serial number: 00362000RVWF
    Coding: 0033622
    Address 16: Steering wheel Labels: 1K0-953-549.lbl
    Part No SW: 1K0 953 549 HW: 1K0 953 549
    Component: Lenksäulenmodul 012 0030
    Coding: 0000002
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 900 F HW: 8P0 920 900 F
    Component: KOMBIINSTR. VDO H72 0210
    Revision: D03 Serial number: 1249DD03013973
    Coding: 0004448
    Shop #: WSC 00411 210 03906
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Revision: 08 Serial number: 25001049270233
    Coding: 3D3F0B42072103
    2 Faults Found:
    00469 - Infotainment Databus in Single Wire Operation
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 119
    Mileage: 232699 km
    Time Indication: 0
    Date: 2011.02.11
    Time: 17:20:30
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 159
    Mileage: 233477 km
    Time Indication: 0
    Date: 2011.02.28
    Time: 18:53:32
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D03 Serial number: AUX7Z0D9FND0BK
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
    Part No: 8P0 959 801 E
    Component: Tuersteuerger. H10 0030
    Coding: 0000016
    1 Fault Found:
    00912 - Window Regulator Switch; Front Left (E40)
    008 - Implausible Signal - Intermittent
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 G
    Component: EPS_ZFLS Kl.9 1301
    1 Fault Found:
    Freeze Frame:
    Mileage: 3440 km
    Temperature: 20.0°C
    Voltage: 12.50 V
    Voltage: 12.30 V
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 E
    Component: KSG H04 0050
    Coding: 188000186D088505489F016000
    Component: Sounder n.mounted
    Component: NGS n.mounted
    Component: IRUE n.mounted
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 HW: 8P4 035 382
    Component: AB2 SUBWOOFERBOXH02 0160
    Revision: 00001 Serial number: 10000001189590
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
    Part No: 8P0 959 802 E
    Coding: 0000016
    Address 56: Radio Labels: Redir Fail!
    Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
    Component: concert II EU H51 0100
    Revision: 01S Serial number: AUZ2Z3D1535597
    Coding: 0001001
    Address 62: Door,Rear Left Labels: 8P4-959-801.lbl
    Part No: 8P4 959 801 B
    Component: Tuer-SG H10 0010
    Coding: 0000144
    1 Fault Found:
    00934 - Electric Window Motor; Rear Left (V26)
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No: 8P4 959 802 B
    Coding: 0000144
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    Fossie
    2,746
    Post Thanks / Like
    At the risk of repeating myself check out ALL the fault codes on this RT web site :-
    Category:Fault Codes - Ross-Tech Wiki
    18,288
    Post Thanks / Like
    Check the ecu connector isnt loose as thats what it seems like.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
