Folks - have jumped over from the A3 8P forum, hope someone can shed some light on this VCDS scan.
The 1.9tdi Sportback is cutting out going over bumps - have checked physical connections etc. The scan my mate performed below reveals the repeated 01314 code regarding the engine control module - could this be causing the problem?
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 7D
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Sporadic communication error 1000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door,Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 CC HW: 028 101 183 2
Component: R4 1,9L EDC 0000SG 6231
Revision: 12345678 Serial number: AUX7Z0D9FND0BK
Coding: 0000071
Shop #: WSC 06314 000 00000
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 N
Component: ASR FRONT MK70 0103
Coding: 0017025
Shop #: WSC 06435 000 00000
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
Component: KlimavollautomatH12 0150
Revision: 105846 Serial number: 8P0820043D
1 Fault Found:
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 198
Reset counter: 119
Mileage: 226825 km
Time Indication: 0
Date: 2010.09.18
Time: 21:59:02
Freeze Frame:
Temperature: 4.5°C
Voltage: 12.10 V
RPM: 0 /min
Load: 0.0 %
Load: 9.0 %
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
Component: Bordnetz-SG H34 0301
Revision: 00H34000 Serial number: 00000001126281
Coding: 01884F02B214100000160000160000000000FE0F5C
Shop #: WSC 00000 000 00000
Part No: 8P2 955 119 B
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 00000
3 Faults Found:
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
00188 - Control Circuit 1; Relay for Supply Voltage Terminal 50
010 - Open or Short to Plus - Intermittent
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
Component: Airbag 9.41 H10 2620
Revision: 91H10262 Serial number: 00362000RVWF
Coding: 0033622
Address 16: Steering wheel Labels: 1K0-953-549.lbl
Part No SW: 1K0 953 549 HW: 1K0 953 549
Component: Lenksäulenmodul 012 0030
Coding: 0000002
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 900 F HW: 8P0 920 900 F
Component: KOMBIINSTR. VDO H72 0210
Revision: D03 Serial number: 1249DD03013973
Coding: 0004448
Shop #: WSC 00411 210 03906
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 25001049270233
Coding: 3D3F0B42072103
2 Faults Found:
00469 - Infotainment Databus in Single Wire Operation
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 3
Reset counter: 119
Mileage: 232699 km
Time Indication: 0
Date: 2011.02.11
Time: 17:20:30
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 159
Mileage: 233477 km
Time Indication: 0
Date: 2011.02.28
Time: 18:53:32
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D03 Serial number: AUX7Z0D9FND0BK
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
Part No: 8P0 959 801 E
Component: Tuersteuerger. H10 0030
Coding: 0000016
1 Fault Found:
00912 - Window Regulator Switch; Front Left (E40)
008 - Implausible Signal - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 G
Component: EPS_ZFLS Kl.9 1301
1 Fault Found:
Freeze Frame:
Mileage: 3440 km
Temperature: 20.0°C
Voltage: 12.50 V
Voltage: 12.30 V
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 E
Component: KSG H04 0050
Coding: 188000186D088505489F016000
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH02 0160
Revision: 00001 Serial number: 10000001189590
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
Part No: 8P0 959 802 E
Coding: 0000016
Address 56: Radio Labels: Redir Fail!
Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
Component: concert II EU H51 0100
Revision: 01S Serial number: AUZ2Z3D1535597
Coding: 0001001
Address 62: Door,Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 B
Component: Tuer-SG H10 0010
Coding: 0000144
1 Fault Found:
00934 - Electric Window Motor; Rear Left (V26)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 B
Coding: 0000144
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
Chassis Type: 1K0
Coding: 0000071
Coding: 0017025
1 Fault Found:
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 119
Mileage: 226825 km
Time Indication: 0
Date: 2010.09.18
Time: 21:59:02
Freeze Frame:
Temperature: 4.5°C
Voltage: 12.10 V
RPM: 0 /min
Load: 0.0 %
Load: 9.0 %
Coding: 00062736
Shop #: WSC 00000
3 Faults Found:
Coding: 0033622
Coding: 0000002
Coding: 0004448
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 119
Mileage: 232699 km
Time Indication: 0
Date: 2011.02.11
Time: 17:20:30
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 159
Mileage: 233477 km
Time Indication: 0
Date: 2011.02.28
Time: 18:53:32
Coding: 0000016
1 Fault Found:
1 Fault Found:
Freeze Frame:
Mileage: 3440 km
Temperature: 20.0°C
Voltage: 12.50 V
Voltage: 12.30 V
Coding: 0000016
Coding: 0001001
Coding: 0000144
1 Fault Found:
Coding: 0000144
