Hi
I've taken out my instrument cluster, swapped it with another one cause it was literally "broken" I replaced the whole thing (I threw away the old cluster->which I shouldn't have done!) Now i'm stuck...
When I start the car, it dies after less than a second...
(the instrument cluster is showing me all sorts of weird things:
-the temperature goes to the maximum
-rpm-meter is going to the maximum, passing the 6000rpm even and goes back directly
-the mileage doesn't show at all totally dark!
HELP can anyone tell me what to do?
I've scanned with VCDS and got this:
Chassis Type: 1K0
Scan: 01 03 09 15 16 17 19 25 42 44 46 52 7D
VIN: WAUZZZ8P64A172453 Mileage: 0km/0miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0000SG 5705
Revision: 12345678 Serial number: AUX7Z0D3FNP01K
Coding: 0000032
Shop #: WSC 01317 552 00000
VCID: 2756F9C2A9B70224
No fault code found.
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0023174
Shop #: WSC 06435 000 00000
VCID: 3A7030B64A058FCC
3 Faults Found
00810 - Sensor 1/2 for Brake Pressure
005 - No or Incorrect Basic Setting / Adaptation
01423 - Lateral Acceleration Sensor (G200)
00778 - Steering Angle Sensor (G85)
Address 09: Cent. Elect. Labels: 8P0-907-279-23-B.lbl
Part No SW: 8P0 907 279 HW: 8P0 907 279 *
Component: Bordnetz-SG 1.0 H30 0501
Revision: 00030000 Serial number: 00000000680416
Coding: 00884F0002141000000000000000000000
Shop #: WSC 00000 000 00000
VCID: FAF070B68A85CFCC
Component: Fehler Lin-Slave 01
1 Fault Found
02071 - Local Databus
004 - No Signal/Communication
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0010602
VCID: 438E4D523DCFCE04
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 HW: 1K0 953 549
Component: Lenksäulenmodul 012 0030
Coding: 0000002
VCID: EFE651E2C1C79A64
Address 17: Instruments Labels: None
Component: KOMBIINSTR. VDO
Coding: 0000140
Shop #: WSC 00999 444 64523
VCID: 55AA830AC35B40B4
2 Faults Found
00668 - Supply Voltage Terminal 30
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 00000010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 1
Time Indication: 0
Date: 2000.01.04
Time: 00:37:53
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 00000011
Fault Priority: 1
Fault Frequency: 1
Time Indication: 0
Date: 2000.01.01
Time: 00:00:15
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 2500104406021F
Coding: 3D0F0900071100
VCID: 2854FAFEA4A90D5C
Address 25: Immobilizer
Cannot be reached
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000016
Shop #: WSC 00150 216 80752
VCID: 39722FBA4F0384D4
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 F
Component: EPS_ZFLS Kl.9 1301
VCID: 2E580CE6864D536C
2 Faults Found
02546 - Steering Limit Stop
Freeze Frame:
Mileage: 8560 km
Temperature: 19.0°C
Voltage: 12.40 V
Voltage: 12.20 V
Freeze Frame:
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 018800186D288505484AC67000
VCID: F9F26FBA8F83C4D4
Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Part No: 1K0 907 719
Component: Neigungssensor 003 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0010
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Component: Tuersteuerger. H09 0010
Coding: 0000016
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
Component: PTC-Element 0404
Revision: 00700000 Serial number:
VCID: 2C5C06EEB051217C
Chassis Type: 1K0
Coding: 0000032
Coding: 0023174
3 Faults Found
1 Fault Found
Coding: 0010602
Coding: 0000002
Coding: 0000140
2 Faults Found
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 1
Time Indication: 0
Date: 2000.01.04
Time: 00:37:53
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Time Indication: 0
Date: 2000.01.01
Time: 00:00:15
Cannot be reached
Coding: 0000016
2 Faults Found
Freeze Frame:
Mileage: 8560 km
Temperature: 19.0°C
Voltage: 12.40 V
Voltage: 12.20 V
Freeze Frame:
Coding: 0000016
