Adrian S FluxJBS
Results 1 to 13 of 13
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    752
    Post Thanks / Like
    Exclamation Auto Window Closure 8L ??
    I've found about a million threads (maybe a slight exaggeration...lol) related to the enabling the auto window closure in vag-com they all seem to suggest using the forum search and not actually how to do it
    I found one threat that said something like going into comfort system and then it talked about adding bite’s but i cant see anywhere to add anything
    Can this be done on the 8L ?
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
    bez101's Avatar
    Jul 2008
    3,425
    Post Thanks / Like
    you want auto close ?
    on the key or window switch ?
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    752
    Post Thanks / Like
    Sorry i should have said.
    I meant when you lock the doors with the key fob, all you need to do is hold the button until the windows start to move and you can let go of the button and the windows still close.
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    752
    Post Thanks / Like
    Anyone
    Oct 2009
    46
    Post Thanks / Like
    That vehicle should use a 35-Central Locking module and Comfort Closing via Remote Control may be possible. Post the Auto-Scan and the model year.
    Edit, after reading that again it sounds like comfort closing is already activated, so you will need to hold the button until the windows are done opening or closing.
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    752
    Post Thanks / Like
    Quote Originally Posted by Dana @ Ross-Tech View Post
    Thanks for the reply ;-)
    Yes it does use 35 (not 46 like a lot of guides say).
    Its a 2001 A3 1.8T Sport.
    The standard setting is like you say, you keep your finger on the fobs lock button and it closes the windows, but as soon as you let go of the button the windows stop going up.
    What I'm trying to do (as many say they have done) is make it so that all i would need to do is keep my finger on the lock button until the windows start to move then take my finger (or should that be thumb...lol) off and the windows will still keep going up.
    Thanks again
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    752
    Post Thanks / Like
    I keep seeing people talking about blocks and bites but All i see in vag is channels and groups
    sulaiman's Avatar
    Jun 2006
    London
    282
    Post Thanks / Like
    Quote Originally Posted by A3 T View Post
    Thanks again
    That's how it works mate, although I would be interested if you manage to find a way in which they continue going up without holding it.
    A3 TDI Sport
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    752
    Post Thanks / Like
    Quote Originally Posted by sulaiman View Post
    I've just found this thread : http://www.audi-sport.net/vb/vcds-formerly-vag-com-forum/74241-window-closure-key-fob.html
    Have a look at post 8 and 9 (and the link in post 8)
    I just cant see how its done....lol
    Oct 2009
    46
    Post Thanks / Like
    The mentioned vehicles are (8P) CAN bus as per the platform chart breakdown:
    Ross-Tech: VAG-COM: Audi A3 Applications
    Your vehicle does not use Long Coding so Bytes/Bits don't apply. The coding for these older platforms was a simple addition/subtraction of the total sum of numbers to get a final coding.
    This is (basically) similar to the diagnostic difference between my (1J/9M) Mk4 2002 Gti and the (1K/AJ) Mk6 2010 Gti.
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    752
    Post Thanks / Like
    Thanks again for your reply
    Does that mean there is a different way of doing it or cant it be done with the 8L ?
    Oct 2009
    46
    Post Thanks / Like
    Can't be done and this is a limitation of the vehicle, not the scan tool (i.e. VCDS)
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    752
    Post Thanks / Like
    Ok thanks mate
    Does that mean that vag is only good on this car for reading fault codes and not for doing any “tweaks”?
