Hi guys
I did my firs vag scan today and I'm a bit lost....lol
Am i meant to clear all the faults it finds in the first scan and re-scan?
The reason i ask is that it has come up with things like the alarm being triggered (in multiple places....lol) and temp sensors having faults. And i have receipts with the temp sensors being changed (as well as air mass meter...etc)
Here are my scan results:
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01 -------------------------------------------------------
Controller: 06A 906 032 HJ
Component: 1.8L R4/5VT 0002
Coding: 11500
Shop #: WSC 06435
WAUZZZ8L52A001557 AUZ5Z0A5293082
4 Faults Found:
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 35-10 - - - Intermittent
17704 - Error in Mapped Cooling System (usually temp Sensor or Thermostat)
P1296 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 - -
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0019970
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 H
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8L0 920 980 P
Component: KOMBI+WEGFAHRS. M73 D06
Coding: 00444
Shop #: WSC 01089
XXXXXXXXXXXXXXXXX
Address 35 -------------------------------------------------------
Controller: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 15178
Shop #: WSC 01089
9 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00991 - Interior Lights
28-00 - Short to B+
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
Address 56 -------------------------------------------------------
Controller: 8L0 035 152 B
Component: chorus II GRO 0004
Coding: 00000
Shop #: WSC 06435
End -------------------------------------------------------
LinkBack URL
About LinkBacks
'56 Audi A4 2.0 TFSI Sline SE quattro Avant
2004 Audi A3 1.6FSI
