Backdraft MotorsportDNA Tuning
Results 1 to 19 of 19
    tdi-man's Avatar
    Jul 2009
    991
    Post Thanks / Like
    Special adaptations: Login code
    Special adaptations: Login code ????? does any body know what this is in version 10.6.2
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium door inlays / panal filter / Egr delete / custom map with hot start fix + warm idle fix / Hybrid Turbo / Helix clutch / 12mm Rear spacers / 10mm Front spacers
    213 bhp - 294 ft lb - 399 nm
    Wifes car - Mk4 Golf GT TDI 150 - 18s - remapped
    FOR SALE
    TANDEM PUMP
    Oct 2009
    46
    Post Thanks / Like
    10.6.2 is outdated and updates are free: Ross-Tech: VCDS: Downloads: Current Release and Manual
    The Beta release was just updated on the 5th: Ross-Tech: VAG-COM: Current Beta
    If you need assistance with a specific procedure or Login, post the Auto-Scan from either of our current releases so I can see what Ecm and Engine code this is as mentioned here security access codes needed
    tdi-man's Avatar
    Jul 2009
    991
    Post Thanks / Like
    im not very good at posting pics and i have your diect email address please ?
    FOR SALE
    TANDEM PUMP
    tdi-man's Avatar
    Jul 2009
    991
    Post Thanks / Like
    im trying to log into engine 01 security access in vcds 10.6.3 and it comes up and says....
    ENGINE CONTROL UNIT (J248/J623) SECURITY ACCESS
    PRIOR TO ADAPTING A NEW USED ENGINE CONTROL UNIT THE VECHICLE SPECIFIC PIN/SKU ( IMMO-LOGIN) OF THE USED ENGINE CONTROL UNIT HAS TO BE USED TO ENABLE THE ADAPTION. YOU'LL FIND THE PIN/SKU ON THE KEY TAG OF THE ADDITIONAL KEY (OF THE DONOR CAR ) OR YOU CAN ACQUIRE IT THROUGH YOUR RESPONSIBLE DISTRIBUTION CENTER OR IMPORTER.
    FOR SALE
    TANDEM PUMP
    18,288
    Post Thanks / Like
    Do you have a log of the car?
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    tdi-man's Avatar
    Jul 2009
    991
    Post Thanks / Like
    i can get one but not very good a posting up pics .
    what log do you want me to do and can email it u
    FOR SALE
    TANDEM PUMP
    18,288
    Post Thanks / Like
    All you have to do is copy & paste the whole text in, no pics required.
    Oct 2009
    46
    Post Thanks / Like
    Hi,
    I noticed the other thread and this video may help explain how to copy and paste the Auto-Scan to a forum:
    YouTube - ‪how to autoscan and post the results.‬‏
    If you are a registered user, and you prefer to work via email with the scan, please sent it to Support:
    Ross-Tech: Contact
    18,288
    Post Thanks / Like
    What exactly are you trying to adapt & genuine cable or chinese illegal?
    tdi-man's Avatar
    Jul 2009
    991
    Post Thanks / Like
    i want to turn my tick over back down.
    i turned it up using vag com 812.5 using code 12233 in 01 engine 16 security code.
    but have since got rid of that cable i have 10.6.4 clone cable and that code dont work .
    i have also used genuine cable and 12233 code dont work.
    any help please thanks
    FOR SALE
    TANDEM PUMP
    tdi-man's Avatar
    Jul 2009
    991
    Post Thanks / Like
    FOR SALE
    TANDEM PUMP
    Oct 2009
    46
    Post Thanks / Like
    If you have a genuine VCDS system to post a complete Auto-Scan from, please do so. If you do not, try contacting the pirate ship support team that supplied the mentioned 10.6.4 clone cable.
  14. Thanks NHN thanked for this post
    Likes NHN liked this post
  15. #13
    18,288
    Post Thanks / Like
    Well said, I cant help you either sorry, I dont support clone cables.
  16. #14
    tdi-man's Avatar
    Jul 2009
    991
    Post Thanks / Like
    it does the same doesnt matter which lead i use clone or genuine
    FOR SALE
    TANDEM PUMP
  17. #15
    Jul 2007
    London
    1,574
    Post Thanks / Like
    12233 is the login code for 4 pot tdi engines. Some v6 tdi will take a 26262 login but many will not work. For iddle speed adaptation you dont need a login code, just go to engine, adaptation channel 1 and modify the value. Some have a 32768 value, increase or decrease the value as required... Use the genuine lead to keep folks happy
    FOR SALE:
  18. #16
    tdi-man's Avatar
    Jul 2009
    991
    Post Thanks / Like
    help needed because ive entered wrong code i need to leave for 40 mins each time ? do i need to leave car running ? or just leave engnition on ?
    FOR SALE
    TANDEM PUMP
  19. #17
    Jul 2007
    London
    1,574
    Post Thanks / Like
    No mate, just remove the key from ignition for a minute or two then start again...
    FOR SALE:
  20. #18
    tdi-man's Avatar
    Jul 2009
    991
    Post Thanks / Like
    Mapping software said 40
    Mins each time ?
    FOR SALE
    TANDEM PUMP
  21. #19
    tdi-man's Avatar
    Jul 2009
    991
    Post Thanks / Like
    have left ignition on all after noon and i think ive fixed it i can now access security adaption in engine ecu using code 12233 and altered tick over back to 840 .
    back to the mappers soon then.
    FOR SALE
    TANDEM PUMP
