UnicornVAG Check
    Feb 2011
    14
    Post Thanks / Like
    Help with the Cruise coding near Taunton
    Hey all, I pick up the parts for the cruise retrofit tomorrow, is there anyone around the Taunton area that can help with the coding? Wouldnt mind getting a scan done as well as i have only just purchased the car and would be interested as to what comes up.
    Ive got an A4 B7 3.2 Avant.
    Kris
    Feb 2011
    14
    Post Thanks / Like
    Fitted the stalk today, instead of buying new lower cowling i just used a dremel and half round file to extended the gap on the original, saves about 26 bucks f anyone is planning this in the future.
    Now thing is i need it coded in, is there anyone in the south west that can help out? willing to drive and provide beers/money.
    will89's Avatar
    Jul 2010
    358
    Post Thanks / Like
    I'm looking to do this mod to my a4. On the vcds user map there is someone in taunton. I'm in gloucester but I'm often down there too. Have a look on the user map and you'll see who I mean and just pm them.
    Feb 2011
    Somerset
    14
    Post Thanks / Like
    Hi,
    I have cruise control fitted that does not work and I work in Taunton and also need a vcds scan to see what issues it brings up, can you let me know if you find someone in Taunton who can scan.
    A4 Avant 2.7 tdi.
    Stage 1 Remap.
    Feb 2011
    14
    Post Thanks / Like
    Yeah will do, have already messaged dave_ph the local guy in Taunton so i'll let you know the response i get.
    The mod is real easy Will, just make sure you have a good torx screw driver set and i found a ratchet set with the arm that can kink very helpful. Give us a shout if you need a hand with it.
