can any body help need to get in to 01 engine security access 16 but not sure of the access code ?
Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium door inlays / panal filter / Egr delete / custom map with hot start fix + warm idle fix / Hybrid Turbo / Helix clutch / 12mm Rear spacers / 10mm Front spacers
213 bhp - 294 ft lb - 399 nm
Wifes car - Mk4 Golf GT TDI 150 - 18s - remapped
FOR SALE
TANDEM PUMP
What do you need to access, is it for cruise cause it does popup what the code is.
Coding, Scanning, Installs, Parts, VCDS Seller
"Live as if you were to die tomorrow, Learn as if you were to live forever"
engine 01 use to be 12233 but got a new cable and that dont work..
FOR SALE
TANDEM PUMP
12233 is a common Login for the older (non PD or CR) Tdi engines for certain adaptation channel access. What are you attempting to do, and to what car? Please post the Auto-Scan if you need additional info about a specific procedure.
Trying to get into engine 01 ecu on a 140 tdi bid engine code bit keeps kicking 12233 out ?
FOR SALE
TANDEM PUMP
