Anyone know if it is possible to test the turn signals on the instrument cluster (2004 A6 C5) using the VCDS my right hand turn signal is very dim. I have borrowed the software and lead for the weekend to see if I can find the fault.
Nick
Nick
try running output tests in the instrument cluster.
Cheers will give it a try
Nick
Tried the instrument output tests, it tests everthing on the cluster apart from the turn signal bulbs. Anyone got any ideas if there is another way to test them with VCDS.
Nick
Take cluster out, remove front fascia, plug in temp & check the differences between left/right at same time inspect what light source it uses, 04 A6 cluster isnt showing bulbs in etka, so led's, reckon possibly going faulty or power supply to it has a dodgy circuit, maybe dry joint somewhere, who knows.
Coding, Scanning, Installs, Parts, VCDS Seller
"Live as if you were to die tomorrow, Learn as if you were to live forever"
Mines god a problem abit like this, right hand signal works on quick indicators, but not on full ones.
To do: None yet.
