DNA TuningDTUK
    Westy's Avatar
    More Air then Fuel!
    Dec 2008
    12,881
    Post Thanks / Like
    Anyone had trouble with the latest version of VCDS?
    I'm using version 10.6 and when I log the measuring blocks of the engine module it is telling me that there isn't a label file for it (8N0 906 018 BH). I've done a search for this label file under the label folder and it doesn't exist.
    I followed Ross-Tech's instructions for manually creating a label file but that doesn't seem to have worked correctly either.
    The other problem I'm having is logging block 020 to read the fuel trime/timing pull. All other blocks seems to be giving me results except this one which just reads 0 on all 4 fields. Now i'm not sure if this has something to do with the above label file being missing or something else.
    Has anyone else had this problem or know what I should check?
    TIA
    FOR SALE
    - BAM connecting rods
    - 1.8T cams
    - K03 OEM Exhaust Mani from AEB head
    - 1.8T Water pump, only a year old. (5K miles)
    - OEM S3 back box complete with both bits of trim
    S3 TAM's Avatar
    Hole in pocket getting bigger!
    Oct 2009
    London & Hertfordshire
    492
    Post Thanks / Like
    I've checked my label files and it doesn't appear to be there on mine as well.
    Revo Stage 2 with all the Gear
    BHP = 274 / Torque = 293
    Oct 2009
    46
    Post Thanks / Like
    I suspect you ran control module maps as described here: Control Module Maps - Ross-Tech Wiki
    If so they contain the data from the module(s) you mapped and we can use them in combination with the repair manual or legwork/research to create label files. Please send the maps and a complete Auto-Scan to: Support -at- Ross-Tech.com
    Westy's Avatar
    More Air then Fuel!
    Dec 2008
    12,881
    Post Thanks / Like
    Thanks for the reply Dana, I'll send over the files.
    FOR SALE
    - 1.8T cams
