JBSAMD Technik
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    998
    Post Thanks / Like
    Couple of fault codes on my mates 3.2?
    A mate has an 04 plate 3.2 dsg and recently has had the engine light pop on a couple of times, the first time I deleted the code and left it at that but today it reappeared with another code as well.
    Address 01: Engine Labels: 022-906-032-BDB.lbl
    Control Module Part Number: 022 906 032 CB HW: Bas isX 3
    Component and/or Version: MOTRONIC ME7.1.1 5604
    Software Coding: 0000178
    Work Shop Code: WSC 06435 000 00000
    VCID: 4D9A6966AD57
    2 Faults Found:
    19598 - Oxygen (Lambda) Sensor B2 S1: Signal Implausibly Lean
    P3142 - 008 - Implausible Signal - Intermittent
    17599 - Linear O2 Sensors: Before CAT: Reversed
    P1191 - 008 - Implausible Signal - Intermittent
    Readiness: 0000 0100
    The first code is the one that appeared last time, as regards the second one, the sensors and wiring etc. have never been touched so that is a strange one.
    Apart from the codes, the car runs fine and has only done 29k miles
    Any ideas anyone?
    Brilliant Red S3
    Gone
    2005 A3 3.2 quattro S-line Sportback dsg Avus silver
    2005 A3 3.2 quattro Sport Sportback dsg Black
    Jan 2007
    Chelmsford, Essex
    456
    Post Thanks / Like
    Hi had a lambda go down last year. These sensors dont fail completely but dropout at odd points in there temperture range.
    also check for a broken earth strap ( its the metal rod from the gearbox to the mainifold) Cost less then 10 quid with new bolts. Mine was broken under the head of the bolt.
    B2 S1 is the nearside sensor.
    Remove the air filter and air box to make access eaiser.
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    998
    Post Thanks / Like
    Cheers for the reply. I remember the earth strap as that was missing on mine when I bought it.
    As for the Lambda, I take it that's the one pre cat i.e. in the actual downpipe?
    Don't know why it's saying the lambda's are reversed though, maybe it's just getting confused with the other fault being present.
    Brilliant Red S3
    Gone
