Autoscan wont read anything from the cars diagnostic port.
Selecting "1K - VW Golf/Jetta V"
Comes up with en error, "Function not supported by the gateway"
So going into the "Select Control Module > 01 - Engine" then "02 - Fault Codes" I got a LOAD of various error's
Based on the below, my gut feeling is either the immobiliser or something to do with the glow plugs, but that doesn't explain my my VCDS cable wont read it ??
Any idea's ??
Cheers,
Scott
Thursday,06,January,2011,12:52:00:12701
VCDS Version: Release 10.6.3
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Control Module Part Number: 03G 906 016 CB HW: 028 101 190 0
Component and/or Version: R4 1,9L EDC 0000SG 6176
Software Coding: 0000072
Work Shop Code: WSC 01279 785 00200
VCID: 65CA592BD5E7
8 Faults Found:
17057 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
P0673 - 000 - -
Freeze Frame:
RPM: 1071 /min
Torque: 82.0 Nm
Speed: 0.0 km/h
Load: 9.4 %
Voltage: 14.21 V
Bin. Bits: 11000100
Temperature: 12.6°C
Bin. Bits: 10110000
18049 - Please check DTC Memory of A/C Controller
P1641 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Bin. Bits: 00000100
Temperature: 36.9°C
(no units): 144.0
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 178.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.17 V
Bin. Bits: 00000110
Torque: 0.0 Nm
Torque: 110.0 Nm
18045 - Powertrain Data Bus: Missing Message from Electric Load Controller
P1637 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 178.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.17 V
Bin. Bits: 00000110
Bin. Bits: 00000000
(no units): 0.0
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 178.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.17 V
Bin. Bits: 00000110
Bin. Bits: 00000000
(no units): 144.0
17978 - Engine Start Blocked by Immobilizer
P1570 - 000 - - - MIL ON
Freeze Frame:
RPM: 0 /min
Torque: 178.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.17 V
Bin. Bits: 00000110
Bin. Bits: 00000000
(no units): 0.0
P1650 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 178.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.17 V
Bin. Bits: 00000110
Torque: 0.0 Nm
Torque: 110.0 Nm
16955 - Brake Switch (F): Implausible Signal
P0571 - 000 - - - MIL ON
Freeze Frame:
RPM: 0 /min
Torque: 170.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.53 V
Bin. Bits: 00000110
Torque: 0.0 Nm
Bin. Bits: 0 01 0
Readiness: 0 0 0 0 0
Any idea's ??
Cheers,
Scott
VCID: 65CA592BD5E7
8 Faults Found:
P0673 - 000 - -
Freeze Frame:
RPM: 1071 /min
Torque: 82.0 Nm
Speed: 0.0 km/h
Load: 9.4 %
Voltage: 14.21 V
Bin. Bits: 11000100
Temperature: 12.6°C
Bin. Bits: 10110000
P1641 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Bin. Bits: 00000100
Temperature: 36.9°C
(no units): 144.0
P1650 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 178.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.17 V
Bin. Bits: 00000110
Torque: 0.0 Nm
Torque: 110.0 Nm
P1637 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 178.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.17 V
Bin. Bits: 00000110
Bin. Bits: 00000000
(no units): 0.0
P1635 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 178.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.17 V
Bin. Bits: 00000110
Bin. Bits: 00000000
(no units): 144.0
Freeze Frame:
RPM: 0 /min
Torque: 178.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.17 V
Bin. Bits: 00000110
Bin. Bits: 00000000
(no units): 0.0
P1650 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 178.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.17 V
Bin. Bits: 00000110
Torque: 0.0 Nm
Torque: 110.0 Nm
Freeze Frame:
RPM: 0 /min
Torque: 170.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.53 V
Bin. Bits: 00000110
Torque: 0.0 Nm
Bin. Bits: 0 01 0
