Adrian S FluxAWEsome GTI
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    Post Thanks / Like
    Quick bit of advice needed.
    Hi,
    bit of a noob to VAGCOM and i honestly don't know a lot about it.
    basically i was up at R-Tech on saturday with intentions of having my car remapped.
    turns out its under boosting and ive been advised to get the MAF and MAP sensor changed then return once the problems are sorted.
    Nick at R-Tech advised buying the cheapo ebay version of VAGCOM from ebay to log a few things to check that the car is running correct before taking it back up there.
    My first question is 1. Is this the right thing i'm looking for: VAG COM USB DIAGNOSTIC CABLE 409.1 OBD2 II LEAD VAG-COM on eBay (end time 24-Dec-10 13:00:32 GMT)
    And 2: Is this all i am going to need to be able to log required boost VS actual boost (i'm told this is what i need to be looking for)
    Thanks for any help in advance
    Fahim's Avatar
    Dec 2009
    Wanstead
    280
    Post Thanks / Like
    I bought one of those cables last time, to use on my Audi A3 and it would just keep coming up with a error saying something along the lines off ''cannot read controller'' It would keep trying over and over again and then give up.
    My friend bought one recently too but a clear white one rather than blue, and in his Bora 1.9 it was the same story. Just wouldn't log any details whatsoever.
    So i'd say forget even wasting the money on it!
    Things to do: Lower on coilovers, spacers, front end respray and a full correctional detail!
    18,288
    Post Thanks / Like
    I sell the genuine vcds aka vagcom, pm if interested.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    CHRIS555's Avatar
    DOPE with added OCD
    Jul 2010
    Midlands
    1,937
    Post Thanks / Like
    Can't help on this one but I did read your other thread and just want to wish you luck with getting it all sorted mate
    Best wishes
    Chris
    Oct 2010
    Port Glasgow
    281
    Post Thanks / Like
    can anyone confirm if this is a legitt cable VAG Diagnostics Ltd - VCDS Vag-Com 908, 912, & 10.6 Cables - Sales NHN pm sent
    18,288
    Post Thanks / Like
    No they're not legit & RT are already acting legally against them.
