Anyone ever try adjusting steering assist on an Audi S3 8L in VAGCOM? Here's one guide:
Steering Assist
You can change how much input is needed on the wheel to turn it. It's set at 5 on the GLI.
Select 44 (Steering Assist)
--> 10 Adaptation
Read channel 1.
Lower numbers are harder steering, higher numbers are easier. Range is reported to be between 0 and 6.
And some links...You can change how much input is needed on the wheel to turn it. It's set at 5 on the GLI.
--> 10 Adaptation
Read channel 1.
