AMD TechnikRevo Technik
Results 1 to 9 of 9
    JohnS3's Avatar
    Oct 2004
    3,022
    Post Thanks / Like
    Enable rear DRL on MY10 S3
    Does anyone have a MY10 S3 or later with rear DRLs enabled? If so can you please post your long coding from your central electronics unit? Byte 18 contains the headlight info, I know a MY10 TT can have rear DRLs enabled by changing the UK default of hex 58 to hex 59.
    This is my current coding hex 2B
    This was a simple change on older cars, you just switched from north American DRLs (front only) to Scandinavian DRLs (front & rear) with VCDS.
    If any of the Ross Tech gurus are reading this perhaps you may know how to code this feature.
    Thanks in advance.
    Oct 2003
    up north...
    767
    Post Thanks / Like
    ;-) in case anyone else needs this answering - its 2C
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    18,288
    Post Thanks / Like
    John can you post up/email to me some screen dumps of the CE pages please, so I can see what the headlight stalk coding page looks like, as I was briefly advised there is a setting within the CE to tell it which stalk is fitted.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    JohnS3's Avatar
    Oct 2004
    3,022
    Post Thanks / Like
    Quote Originally Posted by dunk View Post
    Didn't know you were on here too! I'll try this tonight as per the other thread on vagoc.
    JohnS3's Avatar
    Oct 2004
    3,022
    Post Thanks / Like
    I can do that tonight Nige. All the long coding stuff?
    JohnS3's Avatar
    Oct 2004
    3,022
    Post Thanks / Like
    It is indeed, code changed and working a treat!
    JohnS3's Avatar
    Oct 2004
    3,022
    Post Thanks / Like
    Byte 29, bit 6, "Momentary switch for high beam" Now you should be in business!!
    JohnS3's Avatar
    Oct 2004
    3,022
    Post Thanks / Like
    I'll email you the screen grabs...
    Vertigo1's Avatar
    Jul 2006
    1,478
    Post Thanks / Like
    Just had a look at this on my MY11 A3 with Xenons & LED DRLs and byte 18 is showing as 25. The helper shows this as being for an 8P1 !?!??! Anyone have any ideas?
    Lava Grey Audi A3 2.0TDI 170 S-Line with Tech Pack + AMI, Xenon Plus, Comfort Pack, GSM Prep, BOSE, Interior Light Pack, Luggage Pack, Folding mirrors, Boot mat
