EM TuningBadger5
    mad cornish pastie's Avatar
    Audi novice handle with care
    Oct 2010
    cornwall
    83
    ebay vagcom voltage help
    sorry i did read, but can't find the info on here that if you buy the cheap ebay vagcom it will not work or burn out the cable if an after market radio is fitted as it pushes up the k line to 12volts. anyway can someone point me to the thread were the port can be volt tested and if neccesary put in a resister if i read/remember properly.
    many thanks newbie phil
    bearthebruce's Avatar
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    331
    Are you referring to the Ross-Tech Aftermarket Radio Problem page? Brought to you by the people who sell the real deal. Your eBay supplier will give little to no help.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    Oct 2010
    cornwall
    83
    cheers for that, i only want it to turn off the airbag light...
    27,129
    Then I suggest you do 1 of 3 things, buy the genuine article, ask a member with the genuine article to do or get audi to do this for you, ebay leads are crap
