AMD TechnikJuicy
Results 1 to 9 of 9
    waring192's Avatar
    Dec 2009
    North West
    390
    Post Thanks / Like
    Coming home lights help
    Managed a few months ago to get it working with the repair wire etc. Everything works fine but when I select DRL the main lights come on and im able to select dip/main.
    Any idea how I can keep the DRL to just the LED's?
    S3 Sportback - Ibis White
    Factory: Privacy Glass, Cruise Control, Heated Seats, RNS-E, Bluetooth, Bose, Ipod Dock
    Modifications: Revo Stage 2+, Forge CAI, APR HPFP, Milltek TBE - H&R ARB's & Springs - TV Tuner, Reverse Camera
    Wanted: Stock S3 facelift alloys
    evapor8's Avatar
    Jan 2009
    Guernsey, Channel Islands
    463
    Post Thanks / Like
    Do you have auto lights? That sounds like the problem I had when my car was coded for coming home/leaving home.
    If you don't have auto lights I believe the headlights come on with the DRL's (and as such I got the coding removed straight away!)
    Chris
    Car: Phantom Black A3 2.0 TFSI S-Line BLACK EDITION, 3-door, manual
    waring192's Avatar
    Dec 2009
    North West
    390
    Post Thanks / Like
    Nope, dont have auto lights. Im sure I read somewhere that facelifts had slightly different region coding or something?
    waring192's Avatar
    Dec 2009
    North West
    390
    Post Thanks / Like
    King VCDS AKA Nigel, do you have any ideas?
    18,288
    Post Thanks / Like
    Ok 1st of all before you did the CH hack as such did they work as you want to now & its just the CH hack thats changed this?
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    waring192's Avatar
    Dec 2009
    North West
    390
    Post Thanks / Like
    Yep, was fine before.
    18,288
    Post Thanks / Like
    Quite possibly cause you have hacked the ch/lh mode it now thinks the drl position is related to auto lights thus they all come on, your best bet is to have the auto lights system fitted & thus this should resolve this as the drl's would have a seperate switch, ch/lh relies on auto lights anyway to work properly, I can install auto system, pm if interested.
    waring192's Avatar
    Dec 2009
    North West
    390
    Post Thanks / Like
    I have sorted it now!!! I unticked the leaving home BIT and now it doesnt turn on the mains. Still works as before with it unticked!
    18,288
    Post Thanks / Like
    Result.
