Had an issue on the Avant now for a while where when the car is parked up, the brake light are stuck on.
(This is normally fixed by pressing and depressing the pedal)
Its only started happening since somebody reversed into our car cracking the n/s rear tail light.
Normally, i'd replace straight away but i've got a few financial things to sort first.
On the way driving home today after noticing that the brake lights had been stuck on on walking back to the car, the ABS Warning Lamp lights up in addition to the brake warning symbol were lit whilst driving. then shortly after we started getting a flashing glow plug system warning light.
This indicates according to the manual that there is a fault in the engine management.
I've ran a full diagnosic scan using my VCDS and found the following; ( I was wondering if anybody could advise me of my next steps rather than taking the car to the stealers)
(The left rear door not de-safing is unrelated to the brake issue, but wont unlock on anti-hijack deactivate, only unlocks via the unlock button on drivers door control system or key)
VCDS Version: Release 10.6.1 (x64)
Data version: 20100831
Sunday,03,October,2010,13:29:48:12701
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E********* Mileage: 175890km/109292miles
Address 01: Engine Labels: 059-907-401-AKE.lbl
Part No: 8E0 907 401 N
Component: 2.5l V6 TDI 0000SG 0006
Coding: 02005
Shop #: WSC 63251
VCID: 3064F87FDA51
Part No: 00006059
Component: 130 106KC318_1.V14146724482
WAUZZZ8E********* AUZ6Z0D0003157
1 Fault Found:
00741 - Brake Pedal Monitoring
27-00 - Implausible Signal
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 3429
Coding: 04455
Shop #: WSC 06435
VCID: 26481E27E895
1 Fault Found:
00526 - Brake Light Switch-F
27-10 - Implausible Signal - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AD
Component: A4 Klimaautomat 1323
Coding: 00000
Shop #: WSC 63251
VCID: 63CE4733DB27
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 C
Component: int. Lastmodul RDW 0606
Coding: 00001
Shop #: WSC 63251
VCID: 3260F277D45D
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 J
Component: Airbag 8.4EP 1002
Coding: 0010602
Shop #: WSC 63251 000 00000
VCID: 3E78D6471005
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 S
Component: Lenksáulenmodul 0611
Coding: 01002
Shop #: WSC 63251
VCID: 438EA7B37BE7
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 M
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 01401
Shop #: WSC 00726
VCID: 336EF7732B47
WAUZZZ8E04A243080 AUZ6Z0D0003157
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 C HW: 8E0 035 192 C
Component: RNS-E HIGH EU H56 0650
Revision: 42S Serial number: AUZBZ2F2114735
Coding: 0419711
Shop #: WSC 77801 146 52098
VCID: 244C042F9EA9
1 Fault Found:
02005 - Coding Pin
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 183
Time Indication: 0
Date: 2010.08.10
Time: 12:14:36
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0704
Coding: 00001
Shop #: WSC 00000
VCID: EBDEAF13B3F7
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
43-00 - Closed
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BC
Component: Komfortgerát T3B 1412
Coding: 02027
Shop #: WSC 63251
VCID: 73EE37736BC7
Part No: 8E2959802B
Component: Tõrsteuer.FS BRM 0003
Part No: 8E2959801B
Component: Tõrsteuer.BF BRM 0003
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0004
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0004
2 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01561 - Left Rear Door
61-10 - Won't De-Safe - Intermittent
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0419711
VCID: 244C042F9EA9
1 Fault Found:
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 183
Time Indication: 0
Date: 2010.08.10
Time: 12:14:36
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 AA HW: 8P0 862 335 S
Component: FSE_256x BT H38 0600
Revision: 00000000 Serial number: 00000005169720
Coding: 0011722
Shop #: WSC 22782 000 00000
VCID: 75EA096B65B3
I've cleared the fault codes, and i've no doubt that when re-driven that the ABS intermittent fault will return and will more than likely just be a sensor (if not related to the Brake Light Switch - F)
My only major concern is that the Glow Plug Light Warning is still flashing.
Can anybody advise how I can further diagnose whats causing this ?
Need to make arrangements for tomorrow as the Mrs needs the car (or a car) for work![]()
LinkBack URL
About LinkBacks
