Badger5Forge Motorsport
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,084
    Post Thanks / Like
    Cat Sensor Error Codes from VCDS....
    After my Cat Converter had collapsed I had it replaced and all was good, then the emissions light came on. Scanned the car and VCDS kicked up an error with the emissions... I suspected it was a sensor and my suspicions were confirmed when the car sailed through its MOT.
    Have just scanned the car again and 2 faults have appeared:
    17441 - Sensor for Nox (G295): Signal too Low
    P1033 - 002 - Lower Limit Exceeded - MIL ON
    18528 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1: Too Lean
    P2096 - 002 - Lower Limit Exceeded - MIL ON
    So I'm guessing the sensors need to be replaced? How much would I be looking at?
    Thanks,
    Jonny
    Audi A3 2.0TFSI S Line SE DSG
    Cruise Control | Ambient Lights | LED Lighting | Full Leather | RNS-E MK2
    OEM Bluetooth | AUX | CH/LH Lights | MFSW | S3 Pedals | BFT Remap
    JMB Retrofits - North East Retrofit Company
    18,288
    Post Thanks / Like
    Quote Originally Posted by jb0o View Post
    You should ask in the 8P section as this isnt a vagcom query tbh, Khufu has an FSI ask him if he's aware of costs.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,084
    Post Thanks / Like
    Thanks NHN I'll do that...
