Having a play about with the codes in VCDS, I changed the central locking to one click open for all doors, and also tried a few codes to change the clock to 12hr.
Both of these worked, however the 12hr clock came with other unwanted options, so I reverted the code to it's original.
The problems started there; firstly, the outside temperature display (no DIS fitted) is no longer active, it still shows 'OK' and everything else, but the temp is missing.
Then, more catastrophically, I decided to revert the central locking settings, in case for some strange reason that was the cause. (Un)Surprisingly not, however when I tried to change the code back, the code I inputted was not the code that was stored in the module. I eventually got it to go back to the original code, however it will now not lock/unlock with the remote or the button inside - the key only unlocks the drivers door and all the others then have to be done manually.
HELP!!!
Original Codes
Locking (Module 35)
04814
02325
Instruments (Module 17)
00444
00160
Changed Codes (Not nesesarily what I put in, but these are what were stored in the module)
Locking (Module 35)
04608
02321
00244
00160
The codes are now back at original, but the symptoms persist.
2000 A6 C5 1.8T Avant
VCDS-Lite (Registered)
LinkBack URL
About LinkBacks
Robin Reliant
