W8 PerformanceAWEsome GTI
    rob irl tdi's Avatar
    Jul 2010
    239
    Post Thanks / Like
    Side airbag? code?
    Sunday,25,July,2010,22:51:16:20000
    I got the airbag light on after nipping into the shop. My car is a 2004 sport A4
    VCDS Version: Release 10.6.0
    Data version: 20100630
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 J
    Component: Airbag 8.4EP 1002
    Coding: 0010602
    Shop #: WSC 63351 000 00000
    VCID: 3E78F4E3101F
    1 Fault Found:
    01217 - Side Airbag Igniter; Driver Side (N199)
    001 - Upper Limit Exceeded - Intermittent - MIL ON
    Loose connection??
    bearthebruce's Avatar
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    291
    Post Thanks / Like
    Or a failed igniter. Just be careful. Playing with the igniter can set off the air bag.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    18,288
    Post Thanks / Like
    Check under your seat as connections can become loose at some point.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
