DTUKRevo Technik
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    955
    Post Thanks / Like
    air intake temp sensor
    hi ther i wonder if you could help, the problem is when i accelerate and the boost kicks in, it is stuttering for about 1 second then it goes like it should do but it is happening everytime i accelerate, the car is a 2.5 v6 tdi quattro 180 with engine code ake. There is no smoke at all and the engine is smooth and just as it always has been.
    i have had a scan with vag-com and this code was present
    00523 - Intake Air Temp Sensor (G42)
    30-10 - Open or Short to Plus - Intermittent
    is this the maf or something else?
    i have tried disconnecting the maf and driving,could this code be a result of this do you think
    18,288
    Post Thanks / Like
    Well etka when you type in G42 takes me to MAF, but I'm not convinced, check connections to maf & also check the intake air route for any sensors & make sure plugged in ok.
    If I find out if its maf for sure I'll post, but ask your local dealer if a techie can confirm what G42 is & where it is, ring parts department not service.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
