EM TuningBadger5
    Nov 2013
    Heath Hayes
    951
    Big thanks to Rick for tuning my B8 3.0 TDI.
    Big thanks to Rick for remapping my car . He is not only capable of getting big numbers from petrol cars he can get the most out of diesels too.
    Very knowledgeable, tells you everything thats going on and does a great job.
    Karls 3.0 TDI build thread
    If I fit a Hybrid/ bigger turbo I know where I will be going .
    Karl.
    Karls 312bhp A4 3.0 TDI build thread http://www.audi-sport.net/vb/audi-s4...ld-thread.html
    Nov 2013
    Heath Hayes
    951
    Thought I would update this thread after getting the car run on a dyno today.
    Well took the car to MRC in Banbury today. There 4 x 4 rolling road is supposed to be one of the best in the country and more importantly is as accurate as they come.
    Had a few issues with the first 3 runs in that the dyno print outs looked like a roller coaster below 2200 RPM the ESP was disabled but even so it seemed that the car didn't like being on the dyno.
    He showed me how the boost was pulsing up and down as he accelerated upto the point when the turbo started boosting. After that it was OK.
    Doug disconnected the ABS block and tried again and on the 4th and 5th runs it ran properly although I think by that time the car was a little hot as previously It had run nearer 325PS.
    The final corrected figure was 316PS which is 312bhp and 717 Nm of torque which is 529 Lb/ft . This explains why the car picks ups so well past 2200 RPM :D
    Very happy with this, it's what I asked Rick to do, basically it's pretty much maxed out on the standard turbo, torque is higher than I thought it would be but the clutch isn't having any issues, pulls fully loaded with a caravan just fine.
    On the road you hardly ever see the smoke except at night as you are moving, It's a worse case scenario on a dyno.
    Click on the photo to play the video
    Karl
  1. A big thank you to Rick@Unicorn
    By Andrew@A.L.D in forum Unicorn Motor Developments
    Last Post: 23rd January 2013, 17:41
  2. BIG BIG thanks for rick@unicorn
    By AndyA3170 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st January 2013, 21:18
  3. Big Thank you to 3.2 Ju for the re-coding
    By q724 in forum Q3, Q5 & Q7 Forum
    Last Post: 5th November 2012, 21:41
  4. A BIG thank you to jb0o for cruise control install!
    By Abb in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th June 2011, 20:15
  5. A very big thanks to gordybaillie for new wheels
    By alnes in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th May 2008, 10:43
