EM TuningMonster Motorsport
Results 1 to 1 of 1
    Purdy99's Avatar
    Nov 2012
    Bristol
    90
    Need some help, hope you know the answer,
    as i'm hearing alot of good things, i'm hoping you can help me out,
    i have and A4 2.0tdi 170,
    but i have a judder/misfire under full trottle, other then that can runs fine, and can be taken all through the rev range fine, its only under full throttle it judders/misfires
    i've had the car remapped and Dpf delete already, but following this problem the bloke who done it cant find the problem (problem occured a few weeks after the remap and dpf delete)
    also i've fitted the Egr ristricting gasket and cleane out the all the crap around the egr/inlet valve,
    car has had new injectors, fitted around 5000miles ago, i've changed fuel/air filters, checked for boost leaks over and over again, checked all the little air pipes going to and from the turbo actuator, i've only checked the inlet side of the turbo but all was fine (no damage and no play)
    when looking for any fault codes or and issues shown on the computer nothing seems wrong, been up and down the motorway a few hours with VCDS on to see if it would show anything but all is fine,
    so i've had the remap removed by the place that did it, but the car is still the same, the only thing apprently that was different is on standard settings (no remap) its boosting at 1.6 bar, and apprently thats slightly over what standard should be (so i was told)
    the only other thing that i could tell you that might help is when they did the Dpf delete/remove as far as i know they drilled through the dpf to match the bore of the exhaust? some other places are saying they shouldnt of done that, but i have no idea what needs to be done to the Dpf following a remap,
    anyways if you think you can help or can sort it out with hopefully a more reliable remap i would be more then happy to book my baby in,
    hope to hear from you, josh
    Camillia Well don't want to just settle for any average joe now!
    Purdy haha good point, but then again... apparently anything better doesn't exist
    Camillia No it doesn't... Hence why I'm complaining about it... Come on Purdy you can't be this stupid lol
    Purdy lol the hidden point i was saying, is surely it would be smart to stop chasing what doesnt exist.... then maybe... just maybe! it would shut all you girls up who moan about men...
    Camillia Touché
    Classic case of Girls Moaning about Boys...
  1. Need some help with stripping out the interior
    By Amir in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th May 2013, 21:59
  2. New kid on the block - Needs some help
    By AshD in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th March 2010, 18:43
  3. Hello nice to meet you! I need some help
    By mkimjoon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th December 2009, 22:36
  4. I retrofited the storage packet, almost done need some help. pictures
    By Eddie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd May 2009, 09:56
  5. new to the audi world need some help plz
    By jonny_gt in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th September 2007, 15:07
