EM TuningChris Nott
Results 1 to 10 of 10
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,453
    A big thank you to Rick@Unicorn
    Just want to thank Rick for mapping of my 8L S3 and has done a awesome job at it too. Not only did he map it but also found and fixed some issues i had with it that i didn't know about and neither did guys that tried to map it before.
    I dropped of my car with Rick and found that i had a open circuit to my water temp sensor that he fixed. This was something my other mapper didn't find or see when mapping it. I also needed a new ecu as it couldn't be mapped though the OBDII port, that wasn't the only problem with the ECU as it was damaged due to another mapper soldering and desoldering of the chip. Another ecu was found and ordered and fitted by Rick. there were also a few other small issues that have been fixed by me or been in the process of been fixed.
    My basic spec of my engine is a bored and stroked 1.8t to 2067cc using a TDI crank, forged pistons and rods, ported AEB head with supertech valves and spring kit, Piper cams, GTX3076r .82a/r turbo on a CTS manifold and down pipe, uprated fuel pump, 870cc at 3 bar Custom inlet manifold with R32 T/B, big intercooler, Billet Steel flywheel, uprated clutch, Blue haldex and much more.
    During mapping on the road Rick and Gary managed to hit 162 mph in 5th gear and since getting it back i have managed a 182 mph but had to back off as i started to brick it. The engine made over 500+ bhp and has much more to come as it was making that power with 30 psi of boost but my 870cc were maxing out and had no more to give. I have already told Rick that i will be back with 1000cc injectors and ask to up the boost to 35+psi. I'm sure we will hit 570ish bhp as i know my cam timing isn't bang on and there is much more to come from the turbo. Also since getting the car back more heat shielding has been fitted around the turbo and a turbo blanket has been fitted to keep the surrounding pipes and wires don't melt.
    The multi maps that rick has installed and fantastic. Map one is a Valet map that limits the power and the revs to 4000 rpms and at that it make about 80 bhp, good for when you are leaving the car with the MOT guy of anyone you my think they would like to take your pride and joy for a ride. Map two is 20 psi, Map three is 27 psi and map four is 30 psi.
    Launch control is also fun and great for 1/4 miles but can be a bit anti social but good for ****s and giggles as Rick will tell anyone when out on a test drive in my car. Its like a shot gun going off spitting flames about a foot long.Rick also mapped in full throttle shifting that massively increases acceleration when shifting up the gears and keeping the boost up. That also lights up the back of the car with flames and when people see that 70% of people back off. The only problem i have with is now is traction in wet/frosty roads and i can spin all four wheels easy which we did on a test drive with three of us in it and as Rick will tell you me and my friend ain't light weights.
    I have upset a lot of local posh toffs in there Audi R8's and Ferrari 360's and i plan do upset more but there isn't much around that keep up with it.
    Thanks again Rick and i will see you some time in the new year with the 1000cc injectors and asking you to up the boost
    P.S
    A friend of mine with a S3 with a 1.9L GT3071r will be speaking to you in the new year about mapping his
    Pictures and videos will come soon as i just go myself a GoPro hero
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust, Blue Haldex controller
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Jun 2009
    Leeds
    3,453
    Right its been a long time, the sun was out the car was clean-ish it was a good time to get the Lumix out and get some shot of my car everyone is asking for, I managed to get a bit of video with the new GoPro but there not the best as i'm still playing with it. I didn't use full throttle shifting so i took it easy if you would like to call it but the test was from 70 to 140
    By the way the oil pressure gauge needle is sticking so it not always running 4 bar all the time
    FOR SALE
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,505
    I didn't think Rick had a Rolling road?
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    I don't, although I do have access to one, mainly used for non road legal race stuff.<br><br>I use a Race Technology Data logger which gives very accurate WHP figures . &nbsp;The important thing here is the power curve as optimised as possible without having her cook on the rollers.
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Jan 2012
    Stockport, Cheshire
    748
    Hi Andrew,
    thanks for the comments. The car is a credit to you, as it's really well screwed together. Yes, there were the odd issues but to be honest much less than i was expecting for such a highly modded car.
    Really looking forward to seeing the vids!
    Rick
    Jun 2009
    Leeds
    3,453
    Not a problem Rick
    More to come as you know Just got to get them bigger injectors
    FOR SALE
    Jun 2009
    Leeds
    3,453
    Quote Originally Posted by Byzan Pics View Post
    I would rather have mine done on the road under real conditions. You don't get the same air flow though to the engine on a dyno as you do mapping it at 160+mph on the road
    FOR SALE
    Apr 2004
    12,505
    There are many ways to tune, IMHO a bit of both is best as 160 on public roads while logging is less that ideal.
    It was more of how you came about that figure of power that's all.
    I know Rick knows his stuff I follow his work on many forums.
    Jan 2012
    Stockport, Cheshire
    748
    In all honesty, this speed was a bit of an accident - driver thought we were in 4th... The best way, especially on this sort of high power is at Brunters on the runway. It's not that expensive to hire, and well worth it.
    Rick
    Jun 2009
    Leeds
    3,453
    Now collecting parts to break the 600 bhp mark with the help of Rick
    FOR SALE
  1. big thank you to Splathead
    By britadams in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th March 2009, 06:03
  2. Big thank you to Dave
    By JohnS3 in forum Parts Requests
    Last Post: 6th March 2009, 09:28
  3. A Big Thank You to All
    By RS84 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th November 2008, 23:57
  4. A BIG THANK YOU!
    By FactionOne in forum Major UK Events
    Last Post: 14th October 2008, 14:55
  5. Bluefin - big "thank you" to forum members
    By STU_DSG in forum Tuning
    Last Post: 3rd March 2008, 12:24
