W8 PerformanceRevo Technik
    Sep 2003
    Shrewsbury, UK.
    6
    Post Thanks / Like
    TT APX 225bhp will not start, HELP Please.
    i,
    I have a 2000 TT 225bhp with the APX engine. The car will not start, it cranks over as normal but the EPC light does not light when the ignition is on. I have tried to look for fault codes but neither my Snapon scantool or VAGCOM can interrogate the ECU. I have had the ECU checked by a specialist who says there are no faults with the ECU. There appears to be power going to the ECU loom which I checked with a multimeter. Is there anything else (Relays etc) that I may need to check, I am at my whits end!! Thanks for any information.
    TT Spares's Avatar
    .com
    Apr 2010
    Milton Keynes
    19
    Post Thanks / Like
    Bit of a random one but try disconnecting the battery for a few hours to let the ECU reset and then try again. Could also be starter motor related, or not enough juice in the battery.
    Charlie
    Jun 2010
    Post Thanks / Like
    did you find out what the problem was a mine is doing the same thing aswell. any info would be great to help me aswell
