JMB RetrofitsAH Fabrications
Thread: TT Window fault
    TT Window fault
    Hi
    I've got a '99 TT 225 and the passenger window does not seem to rise to its full height. It's only a matter of a couple of mm but it's causing a lot of wind noise at high speed. I'm guessing this is possibly a common fault. Does anyone know if it easily adjusted/repaired? And if so how!?
    Best regards
    P.
    scoTTy's Avatar
    Essex, UK
    1,958
    Press and hold the window down button until it's fully down and don't let go for a further 5 secs. Do the same in the up direction and then repeat down and up again.
    That should recalibrate it.
    MY2010 B8 A4 Avant 2.0TFSI quattro S-line Executive
    Honda CBR1100XX Super Blackbird
    Gone : B6 S4 (AMD stage 3), TT (APR), Golf GTi, CBR600F
    If in doubt?? F L A T O U T
    Dec 2009
    Melbourne Australia
    Smile Keep your windows up. no problem.
    Cheers scoTTy. Do I do the 5 second thingy on the 2nd time I put the window down and up?
    (Thanks again)
    hi,
    i have the same problem with my drivers door. i tried the window reset and it helped a little so will try again. i did all the way down all the way up and hold for 5 secs, hadnt done the hold down for 5 secs.
    T3RBO's Avatar
    Plymouth
    131
    Window reset
    ignition on
    windows all the way down
    windows all the way up, let go of switches
    push them up again and hold for 3-5 seconds
    ignition off
    AUDI TT 225 COUPE|BRILLIANT BLACK|BLACK LEATHER|BOSE|TUNED BY VAGCHECK.COM
