DPMRevo Technik
    Dec 2009
    Post Thanks / Like
    Abnormal Tyre Wear
    I have an Audi TT 2002 quattro. After only 15,000 miles on a set of new tires, they have worn bald. And on each wheel, the tire has worn most on the inside. Each wheel! Is this a common problem on these cars? What is the likely repair that would be required, and how much does it cost? Would you trust anyone else (or any one BUT) an Audi dealer to do this repair?
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    11,565
    Post Thanks / Like
    Thumbs up
    I have an 02 S3 and it does the same but after I did a search on here I found it happens to most people.I have upgraded my suspension and altered the geometry so it is less obvious now and also I change the tyres about from front to rear.
    Hello and Welcome to the site BTW
    If in doubt?? F L A T O U T
    Dec 2009
    Melbourne Australia
    Post Thanks / Like
    Hi voor. Any places you know of where i can get my hands on those geometry settings? i have a 2wd 99 model that does exactly the same thing. ive got a shop that can do the work but id like to be able to give them the settings. regards jj
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    11,565
    Post Thanks / Like
    Glad to help jj this is the link to the info I used S3 Suspension and Set-up Guide let me know how you get on
    Keithrg
    Post Thanks / Like
    My TTS averages about 10K on tyres, am a high mileage driver .. car new July 2008 ... 750 + per week... now at 42K ... so an expensive habit but TTS very very sensitive to worn tyres [still grips but handles horribly when tyres worn!]. Still refit original factory spec .... anyone with idea's to better geometry or tyres that last longer welcomed !
